Undetectable tuner
Old Mar 20, 2018 | 08:40 AM
  #41
BigMike's Avatar
BigMike
Glad my bike is a Twin Cam out of warranty and I have the knowledge to fix or upgrade it as I see fit. I don't anticipate any problems though, but if something does happen, get out the wrenches and go to work. Never have and never will be a slave to an HD service department.
Old Mar 20, 2018 | 08:49 AM
  #42
mjwebb's Avatar
mjwebb
Originally Posted by TomcatCV62
How many remember the days there were zero electronics on the bike......... You could do whatever you wanted to do. Still can do whatever you want to do.........
yeah..I miss 8 Track players and lap seat belts only too..those shoulder strap safety belts are too confining..and what's up with candy bars these days costing a buck!
Old Mar 20, 2018 | 09:02 AM
  #43
Quik's Avatar
Quik
If you take only one thing from this thread it should be....ignore the countess different answers given here and become good friends with a dealership owner and service manager who will not blow smoke up your *** but will tell you what's really up. It can be hard to get on that level of "friend" but it is possible and the real answer is available.
Old Mar 20, 2018 | 09:24 AM
  #44
BigMike's Avatar
BigMike
Per ThunderMax, mileage stored in speedo. Put the stock ecm back and the bike is stock. O2 sensors will have to be swapped as well.
Old Mar 20, 2018 | 10:11 AM
  #45
jd05flhtci's Avatar
jd05flhtci
I guess the only thing to is if you are worried about warranty is leave it stock or use the Harley crap until warranty is up.
Old Mar 20, 2018 | 11:25 AM
  #46
TomcatCV62's Avatar
TomcatCV62
LOL, true true..... Still think my EVO was the best Harley Ive ever owned, but thats just me.
Old Mar 20, 2018 | 04:51 PM
  #47
FatBob2018's Avatar
FatBob2018
just curious why you chose the Torque Cam, 447 presuming, since you went with an aftermarket tune? sounds like once you go outside compliance then the aftermarket cams whoop the SE versions..???
It's that sentiment that illustrates why I wish they would have included the 447 in the FuelMoto cam tests. But they didn't, so we'll never know.
Closest we can know is to use PuttNutt24's SE447 which used an aftermarket exhaust and aftermarket tuner, and compare that to what FuelMoto got from their 114 with aftermarket exhaust and aftermarket tune. Even then, it's not a direct comparison because it's different dynos and different guys running the dyno.
From what I'm seeing on the FuelMoto page, all the cams seemed to have generally similar curves, peak HP from 110 to 118 and peak torque 120 to 126. Compare that with PuttNutt's chart, 111 HP and 129 ft/lbs. That's the SE447 torque cam, and it delivered more ft/lbs than any of the aftermarket cams. HP was on the low end. Seems like what you would expect, right? I imagine that if PuttNutt24'd gone with the HP cam, the opposite would be true, HP would be on the high end of the group and torque toward the lower end.
That's the closest comparison I can find on the web. It shows the SE447 as being generally comparable to the aftermarket cams. But the only true way to know would have been if they would have included the 447 in their overall test; without that, we can't know what variables don't line up. I understand they didn't want to, I don't begrudge them that, I'm just pointing out that we don't have a direct apples-to-apples way to compare them now.
Old Mar 20, 2018 | 08:31 PM
  #48
FLSTFI Dave's Avatar
FLSTFI Dave
Originally Posted by jpooch00
The MoCo has not only shot itself in the foot, it's blown it completely off with strictly enforcing the "no non-approved mods, or else" bullshit, since most folks, at least on this forum, don't seem to be satisfied with these bikes in factory-stock configuration. Plus, apparently, if you do the "Factory-approved" hop-up mods, then you increase the odds of sumping and other issues if you try to actually use that extra power that you paid through the nose for.
Screw that!
Actually, its not the MoCo. The MoCo lost a lawsuit brought by the EPA. The EPA fined the MoCo heavily. The EPA is forcing the MoCo to follow laws that have been on the books for 10 plus years that the MoCo was ignoring. If the MoCo gets caught again there are more big fines for them.
I'm not one to defend the MoCo, but the above is the truth. With the size of these motors if the MoCo spent any time developing them they could make a lot more HP and torque and be reliable. Then we would not have to figure out how to get the power they should have.
Old Mar 20, 2018 | 11:25 PM
  #49
Prot's Avatar
Prot
OEM eight track tape deck still works in my car.
Old Mar 21, 2018 | 06:27 AM
  #50
TomcatCV62's Avatar
TomcatCV62
And, I do believe that is an EVO in your picture..... Nice and Nice.
