Dealer screwed me, the changed changed the firmware.
Old Jul 7, 2018 | 11:06 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
What did they say they did for the coldstart chatter you mentioned in your first post. The auto tensioner would not do that since it is pretty much locked in till the next step and is only going there after a lot of wear.
It still has those two heavy springs that actually give it the appearance of being too tight. They for sure are not going to let it chatter..
Old Jul 7, 2018 | 12:20 PM
ROCKOUT Rocker Products
Sponsor
Not a cheap solution but....
You could buy a tuner such as a Power Vision & read the map (NOT flash the ECM as to void the warranty). Have someone here send you their stock map and compare the two. If they don't match you have your evidence. Worst case flash the new stock flash to your bike... shouldn't be any warranty issues.
Good luck.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Jul 7, 2018 | 12:30 PM
Quik's Avatar
Quik
Did you give the dealer your screaming eagle tuner? Just wondering cause if they didnt have it then it doesnt seem like the tune could have been messed with since they no longer do the "dealer download" on 2017+ bikes.
EDIHD
Engine Mechanical Topics
16
Aug 16, 2018 06:25 AM
KnarleyHarley
The Dyno Room
Nov 16, 2017 06:24 AM
dlporter
Sep 5, 2015 11:07 AM
editbrain
Oct 20, 2010 12:12 PM
blight
Jul 21, 2010 10:23 AM
