switch to syn 3 for all fluids
Old Jul 15, 2018 | 12:31 AM
skeeter86's Avatar
skeeter86
Default switch to syn 3 for all fluids
Im running baq stock m8 with the oil cooler do you need to drain all the oil from the cooler or does it not to be that though just wondering if that little bit will mess withe the syn 3 oil and possibllay void the warrinty?
Old Jul 15, 2018 | 12:54 AM
mmesa005's Avatar
mmesa005
Here are some threads to read through.
https://www.hdforums.com/forum/milwa...estions-2.html
https://www.hdforums.com/forum/milwa...nge-fyi-2.html
Old Jul 15, 2018 | 05:36 AM
dave the welder's Avatar
dave the welder
Just drain the fluids from bolts at the bottom of the bike. Your owners manual describes the procedure. It's easy and don't over think it.
Old Jul 15, 2018 | 06:29 AM
lyork's Avatar
lyork
Man...Harley has everyone on edge about voiding the warranty anymore. Relax people...just change your oil and don’t fret about it
Old Jul 15, 2018 | 07:59 AM
UHDhog's Avatar
UHDhog
I'm going Syn3 in all holes at the 1000 mile service.
Old Jul 15, 2018 | 10:06 AM
KrustyKush's Avatar
KrustyKush
There shouldn't be any problems with mixing the oils. Incompatibility was an issue early on with the synthetics, way back half a century ago. But not anymore.
However, old habits die hard, and I always tend to over-think things. So when I switch to a synth oil, I will do a flush, by installing the new oil, running a hundred miles or so, and then change the oil again. This gets out most of the retained oil. It is expensive and wasteful, and all but certainly unnecessary, but that doesn't stop me.
I doubt that it matters a bit.
Old Jul 15, 2018 | 10:19 AM
TriGeezer's Avatar
TriGeezer
There are much better choices.
Old Jul 15, 2018 | 11:09 AM
UHDhog's Avatar
UHDhog
Agreed. But, this oil is readily available pretty much anywhere you ride, should you need more.
Old Jul 15, 2018 | 12:03 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
wtf did I just read... gotta be from Toledo
Old Jul 15, 2018 | 12:07 PM
TriGeezer's Avatar
TriGeezer
That should not be the primary reason for oil selection.
