Sumping Issue? 2017 SG CVO
Old Aug 18, 2018 | 10:16 AM
  #41
D W K's Avatar
D W K
Ill go look for it. I assumed it had to be underneath somewhere.
Old Aug 18, 2018 | 02:55 PM
  #42
D W K's Avatar
D W K
Well......... I had everything laid out so I could test it after about a 100 mile ride today. Didnt make it home. Bike sumped so bad that it completely stopped.Power was almost completely gone before it sumped. The oil showed about 1 1/2 quarts low and smelled super burned. The bike acts as if it completely lost compression.
Either way I had the second dealer come pick it up off the side of the road so now its a waiting game. To be honest I'm hoping its a complete new motor but we will see.
Old Aug 18, 2018 | 03:01 PM
  #43
Heatwave's Avatar
Heatwave
Member
I'm afraid to say "it'll all depend". If you pretty much pulled over as you were feeling the loss in power, you may not have damaged anything...that's the good news. The bad news is that HD will want to install a new oil pump, if there's no damage to the bearings. And sadly, the new oil pump is unlikely to solve the issue.
Unfortunately the best outcome is that the engine "got tight" from the excessive heat and they authorize a replacement engine. I'm convinced they are shipping all replacement engines with the latest upgrades going into the 2019 engines and that's the fastest path to an engine you can ride with greater confidence. Good luck!
Old Aug 18, 2018 | 03:16 PM
  #44
Dynamick's Avatar
Dynamick
Won't they also install the revised cam plate along with a new pump?
Old Aug 18, 2018 | 03:30 PM
  #45
Heatwave's Avatar
Heatwave
Member
I haven't seen a Harley revised cam plate part #. Not saying it doesn't exist, just haven't seen anyone report a new Cam Plate part # from Harley. I would think if there was one, they would have issued a updated version of SB1450. I think its still the same SB as last Nov.
Old Aug 18, 2018 | 03:38 PM
  #46
D W K's Avatar
D W K
I rode it until to stopped on it own. It seems to have lost all compression. Every light on the dash was on. I was about a mile from the house and was planning on testing the amount of oil coming out of the CPS but she died and would not crank at first, then would crank when it cooled some, but would not start.
Old Aug 18, 2018 | 03:40 PM
  #47
D W K's Avatar
D W K
When I talked to the dealer after it was picked up and he said Harley had shipped him a prototype plate to use on an 18 he had last week. . Harley thinks the oil might be migrating through the bearings and the new plate seals it off. Just what he told me so I have no reason to doubt him.
Old Aug 18, 2018 | 03:46 PM
  #48
Heatwave's Avatar
Heatwave
Member
Sounds like a busted engine. They SHOULD authorize replacement. Let us know.
Haven't heard about a prototype plate for the '17s and 18's but its certainly possible. No clue how oil could "migrate" from anywhere INTO the crankcase. That's a new one.
Old Aug 18, 2018 | 05:23 PM
  #49
Fat11Lo's Avatar
Fat11Lo
Sounds like you may have cooked it, not a bad thing IMO in your case. That, hopefully, should get you a whole new engine
That sounds more like a fix for the transmission oil migration issue, sumping is a whole different situation, although many are confusing the two and some bikes have both issues
Please keep us posted on how things go with the dealer
Old Aug 19, 2018 | 06:03 PM
  #50
D W K's Avatar
D W K
No he knew about the transmission migration issue too. He was very specfic and said a new cam plate. He talked about the possibility of it being piston jets being loose and / or the oil scavenging. He even said, the sumping is coming from a variety of issues and there was no one fix all for them. He even acknowledged Harley is chasing their tails on them. He knew the revisions of the oil pumps etc... seemed to be way in tune with the issues. The only statement he made to me that i dint like is they have not replaced an entire engine on one yet, no matter how hot they got. That the have replaced the pump, plate and top end and sent them out with no issues. Maybe mine will be a first on the bottom end. Hard to say.. I'll know more once they get into it Wed. I can't imagine the bottom end not being hurt. The burnt oil smell was horrible and was even coming out of the exhaust when It cooled enough for me to crank it.
