New recall
Old Nov 8, 2018 | 08:42 AM
  #61
stixvrad's Avatar
stixvrad
Unless I missed something, why the heck haven't owners of bikes covered under this recall ( Mine is) received a letter ? Seems its up to us to find out through sources other than HD.
Old Nov 8, 2018 | 09:50 AM
  #62
texaswiz's Avatar
texaswiz
I am going to take a scientific, wild *** guess at this one. Maybe the reason most of us have not received our "official recall letter" yet is because the MOCO only has one dedicated clerk typing out the letters and they have 138,000 owners to notify. They have said they are taking a 35 million dollar charge to the balance sheet for this particular recall so money is probably a little tight up there. Another reason might be that some eagle eyed Harley Davidson Forum member spied the recall info on the government's official NHTSA site and spilled the beans before the MOCO was ready to acknowledge the recall.
Old Nov 8, 2018 | 10:03 AM
  #63
barneyboy's Avatar
barneyboy
Received my letter yesterday.
Old Nov 8, 2018 | 10:10 AM
  #64
Max Headflow's Avatar
Max Headflow
Originally Posted by lp
And that's not exactly true either. The clutch spring bottoms out the Actuator every time the clutch lever is released.
Bottomed out means the actuator piston will retract no more thus no more fluid is pushed up to the Master cylinder. Worn clutch or not...
I suspect that pooch is right.
Mechanically you don't want to bottom the slave piston. If you do you load the pushrod and take pressure off the clutch. You want the slave piston to have enough return travel that it never bottoms. It only gets pushed in far enough to take pressure off the clutch pushrod.
Old Nov 8, 2018 | 10:26 AM
  #65
aviscomi's Avatar
aviscomi
"dedicated clerk typing out the letters"
I think the days of typing out letters are long gone...Microsoft Word MailMerge replaced that a while back.
Old Nov 8, 2018 | 11:00 AM
  #66
texaswiz's Avatar
texaswiz
Not so much at the MOCO. They are typically 30-40 years behind the modern day curve. You would think that the least they could do would be to put a part timer on the job with the full timer to send out the letters. It wasn't until last year that they replaced their Smith Corona manuals with electrics. Big step up for them.
Old Nov 8, 2018 | 11:11 AM
  #67
stixvrad's Avatar
stixvrad
Thats good to know, but I have two friends both who have not received a letter. I've had my bike sine Nov 2017 and heard nothing.
One guy had a stage one kit put on his 2018 SG and they wouldnt let him take it home until they performed the recall.
They are JUST getting parts in now. So I ask, if its SO dangerous to ride, why the heck didnt letters go out immediately and two, why the heck arent they offering to pick the bikes up with trailers.
Can you imaging the lawsuits if as your riding to the dealer to get this uber important recall work done, the clutch fails and you ride into traffic crossing your path and get nailed?
Old Nov 8, 2018 | 11:24 AM
  #68
PFWiz's Avatar
PFWiz
Just got a call from my dealer. They did my clutch recall while doing other, unrelated warranty work. Now all I need is good enough weather to pick up the bike and then deliver it to my Indy for winter storage.
Old Nov 8, 2018 | 11:41 AM
  #69
KrustyKush's Avatar
KrustyKush
My understanding was that this recall comes from the factory, and was not ordered by NHTSA.
Old Nov 8, 2018 | 12:28 PM
  #70
texaswiz's Avatar
texaswiz
10/11/18: Upon review of the results of the RIC's investigation and analysis, Harley-Davidson's executive management made its determination that a safety defect exists in the subject population and declared a recall to remedy the issue.
NHTSA was in the loop at all stages of the RIC investigation. While the NHTSA did not initiate the recall they more than likely would had were it not for the fact the MOCO did so.
Updated field data showed 265 warranty claims and 29 dealer/customer contacts that appeared to be related to the secondary clutch actuator leaking. Three additional alleged crashes, with no reported injuries were identified that may be related to this issue (bringing the total to five). Because of the crashes it appears that the NHTSA would have stepped in and ordered a recall had the MOCO not done so first.
