Not the normal sumping question
Old Nov 3, 2018 | 09:38 PM
jsrracing's Avatar
jsrracing
Originally Posted by modes
Agreed, but in terms of warranty....sumping and it's repair costs would be the only warranty service on these non water cooled M8s I feel might have been worth retaining it for the 2 year duration.
Adam
There is alway the screaming eagle options to retain warranty . Im pretty sure you mod the motor/ecu they are going to dx the whole powertrain with hd its always a crap shoot . I dont think it is that big of a deal turn the clock back to stock . Thats just my 2 cents .
Old Nov 3, 2018 | 10:00 PM
modes's Avatar
modes
EPA canned maps aren't for me. Had a friend go down that road and the dealer finally tuned it with a tts instead on their dime to get it running correct without a bad hesitation. I guess they had another client who is inexperienced put his bike down due to the same hesitation. Agreement non EPA for me.
Adam
Old Nov 3, 2018 | 10:31 PM
$tonecold's Avatar
$tonecold
While we are on it.....changing out the lifers whilst in there. s&s retainers or oem sufficient? Another glue/bolt to be careful of from reading.
Adam
New cam, new lifters. They don’t have to be premium, I used V-Thunder lifters when I changed the cam in my M8. No problem with them. I put Fueling lifters in my TwinCam and one failed immediately, so premium is no guarantee of quality.
Yes I would use the S&S anti-rotation devices. I wasn’t aware they were available when I changed cams or I would have used them. Yes you need to be cautious removing the bolts that retain them. I will be installing them when I do the big bore this winter.
Old Nov 4, 2018 | 07:21 AM
DRBUICK's Avatar
DRBUICK
LS7 lifters in mine no problems 22,000 miles and will be reusing with my 130 inch.
Old Nov 4, 2018 | 01:44 PM
$tonecold's Avatar
$tonecold
If you go on Summit Racing’s website the choices for LS7 lifters are almost as confusing as the aftermarket choices for Harley. Did you just go with the Delcos?
Old Nov 4, 2018 | 02:20 PM
yobtaf103's Avatar
yobtaf103
Well i just pulled the cam chest apart on mine, another thing to note the crank sprocket is quite slack, as T-man found !
Depends how **** you want to be, he sells a tighter fit one but as with tappet cuffs just better quality items but no history of failures of stock items
Old Nov 4, 2018 | 02:32 PM
modes's Avatar
modes
Looking forward to getting it open. Definitely seems to be a lot of inconsistencies in these engine when it comes to precision.
Adam
Old Nov 4, 2018 | 03:33 PM
jsrracing's Avatar
jsrracing
I used the s@s lifter guides ,pfft plastic in a motor is just not for me .I also had a bent bolt when i removed the oem guides . I also had two lifter cover bolts strip made a easy job a pita . went for a ride today 50 degrees and it was screaming .
Vaquero3660
Feb 3, 2019 09:07 PM
EarlB
Oct 11, 2018 08:15 PM
purpledeuce
Milwaukee Eight (M8)
16
May 22, 2018 07:24 PM
cromagnon
Feb 22, 2011 06:49 AM
OG1
Jun 3, 2009 08:59 PM
