I just heard the front spark plug wire is rubbing against the fuel tank and wearing a hole through the wire 4" above the spark plug boot! Anyone seen this ?
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
In 2018 a retainer was added for the left front plug that secured the wire away from the tank.. Having seen this problem on past bikes, I put some spiral wrap on areas that might rub.
Front outside plug wire.....right where it comes out from under the tank. Just look....you see the wire touching....or the fancy zip tie clip holding it.
