M8 Dyno Numbers
Old Jul 2, 2019 | 09:21 AM
  #171
Beartooth Rider's Avatar
Beartooth Rider
Originally Posted by hdrider1
Just a quick update on the FM124. I've now got 2300 miles on the kit and mileage continues to increase. My last 2 tanks were 38.7mpg and 40.2mpg. Although FM says it's broken in on the dyno, it appears to continue with the breakin process for a couple of thousand miles beyond that.
Thank you for the update and I would like to add that during the last 500 miles of riding with my new FM124, my fuel consumption has stabilized around 37 mpg +/- (during somewhat aggressive riding on twisty roads) and I'm totally OK with that.
I might also add that my wife, who somewhat begrudgingly approved the funding for this build has told me that if we get another bike, it has to perform like this one does now. She noticed the difference in how much less effort I was making with less down shifting exiting the turns to keep up with my son riding solo on a CVO as well as the extra safety margin with more power in passing situations on two lane roads.
I felt like I was riding a 125 against an open class bike, down shifting to get the power I needed coming out of the turns. Now, with the FM124 and the WM8-408 cam, the power band (TQ/HP) is so wide, I can just roll the power on coming out of the turns and compression brake going into the next turn and that was my performance objective on this build. I'm very happy now.
Thank you Fuel Moto and Yellowstone HD!
Old Jul 3, 2019 | 05:30 PM
  #172
Vision's Avatar
Vision
2018 RGS
Revolution 124 Build @ 11.1:1
SE heads
SE 64mm Thottle Body
SE 5.5 injectors
SE Lifters
D&D Billet cat Exhaust
Wood WM8-408 cam
FEULING HP oil pump and plate
SE clutch with AIM SDR plate
Old Jul 3, 2019 | 05:43 PM
  #173
hdrider1's Avatar
hdrider1
Originally Posted by Vision
2018 RGS
SE heads
SE 5.5 injectors
SE Lifters
Wood WM8-408 cam
Based on the build Im guessing either the SE Heads or the exhaust is holding it back a bit. Wonderfully flat torque curve -- what tuner was used?
Old Jul 3, 2019 | 11:13 PM
  #174
Vision's Avatar
Vision
Must be the SE heads. Tuned with Techno Research Direct Link. It actually runs fantastic. I wonder if the stock heads would have been a better option..
Old Jul 4, 2019 | 12:09 AM
  #175
Gar1414's Avatar
Gar1414
Something seems odd about those numbers for a 124. My 117 stage 4 with a 2-1 made those numbers
then I sent the heads off to wards and he ported them even more Han Harley did as well as the intake m. Added a woods 408. And it made this.
Old Jul 4, 2019 | 08:43 AM
  #176
jmd897's Avatar
jmd897
Its definitely heads you should have Andrew Rosa do them he is very good. Also larger TB will help as well. Its probably needs to be milled and cc’d to match the piston with some mild porting. Rosa did right.
Old Jul 4, 2019 | 08:48 AM
  #177
Keithhu's Avatar
Keithhu
Bigger than 64mm? I'd focus on the heads.
  #178
jmd897's Avatar
jmd897
I meant larger injectors not TB since you have a 64mm TB.
Old Jul 4, 2019 | 09:13 AM
  #179
hdrider1's Avatar
hdrider1
I wonder how much each change contributed -- the porting vs the cam change? Why did you change the cam at the same time -- seems that the original cam was doing a pretty good job.
Old Jul 4, 2019 | 09:22 AM
  #180
Vision's Avatar
Vision
I believe the 5.5’s are the larger injectors they make. What I find funny is that I have seen 124 kits push 140/140 with the same configuration. SE Heads, 64mm Throttle body, 5.5 injectors and same compression. Again, the bike rides Fabulous. Scrapping my SE heads, having my stock heads worked and maybe porting the Manifold are the only things I can think of.not sure if it’s worth it though.
