M8 Dyno Numbers
Old Jun 7, 2019 | 09:23 AM
  #161
wallyj's Avatar
wallyj
Yes, the ported heads came pre-installed with appropriate springs.
Old Jun 7, 2019 | 12:45 PM
  #162
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by wallyj
Got excited and forgot to post the specs:
2018 Fat Bob 114
128" Fuel Moto big bore kit
Woods WM8-408 cam with matching lifters
Fuel Moto Level A CNC heads w high lift springs
Screaming Eagle 64mm Throttle Body
Screaming Eagle 64 MM intake manifold - Ported (FM/Ward)
Screaming Eagle 5.5 gps injectors
Screaming Eagle clutch springs
S&S Oil pump, cam plate, and lifter cuffs
K&N / Fuel Moto modified Ventilator air cleaner
D&D Fat Cat exhaust
I did the build, and Piper Performance did the tune using TTS Mastertune
Well done, thank you for sharing!
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Jun 7, 2019 | 01:49 PM
  #163
Beartooth Rider's Avatar
Beartooth Rider
2018 Fat Bob 114
D&D Fat Cat exhaust
You chose a good build and you got good results. The D&D Fat Cat exhaust looks like it's doing a good job for you and I wish I had included the S&S lifter cuffs in my build. Enjoy your ride!
Old Jun 7, 2019 | 02:18 PM
  #164
wallyj's Avatar
wallyj
Red face
Thanks Beartooth.
I just picked up the bike. I did a 10 mile test ride, warmed it up good, did some low and variable speeds, then laid into it. Only broke 100 mph 5 times . Hopefully that is out of my system now and I can just enjoy the power during more relaxed riding, passing trucks, etc.
It runs smoothly at all speeds and throttle openings. It comes on hard and I think it will keep me happy. No more performance mods needed. That might be the first time that phrase ever came out of my mouth!
Piper Performance did a really nice job with the tune. I would highly recommend them. Shop is organized, very well equipped, and neat as a pin. Cliff took an entire day on the tune, and it shows.
Old Jun 7, 2019 | 03:55 PM
  #165
Beartooth Rider
Thanks Beartooth.
The extra power is nice riding in a group in passing situations on two lane roads, when the rider in front of you considers it safe to pass, you can have confidence in your performance to go with him.
Didn't you start out with the Power Vision on this build before you found Cliff at Piper Performance?
Old Jun 7, 2019 | 05:24 PM
  #166
wallyj's Avatar
wallyj
I did start with Powervision. Cliff even started tuning with it, but called me and discussed how he thought he would get the best results using TTS. I have a lot of $ in this build, and figured a few more bucks to get it just right was worth it. I'm reasonably familiar with what is available in PV, so when I picked up the bike, I had Cliff go through some of the things TTS had that were different or not in PV. One that stuck out is the setting for cam timing. Either way, I got some good use out of the PV and learned alot about it. I guess Ican add a license to it for another bike if I want to use it again. I know Fuel Moto tunes similar builds with PV, so I'm sure it is capable.
Old Jun 7, 2019 | 06:23 PM
  #167
Beartooth Rider
I get it, trust me once you start down that road, it's all in the pursuit of happiness.
Old Jun 8, 2019 | 12:37 PM
  #168
wallyj's Avatar
wallyj
__________________
Thank you for recommending a great combination. Every time I talked to someone at FM, they were really helpful, and very patient.
Went for a nice ride this morning and thoroughly enjoyed the power.
Old Jun 26, 2019 | 12:56 PM
  #169
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Old Jun 30, 2019 | 09:11 PM
  #170
hdrider1's Avatar
hdrider1
Originally Posted by hdrider1
I guess I wasn't as heavy handed on the throttle -- my first fill up was 34.8mpg and my second was 36.7..
Just a quick update on the FM124. I've now got 2300 miles on the kit and mileage continues to increase. My last 2 tanks were 38.7mpg and 40.2mpg. Although FM says it's broken in on the dyno, it appears to continue with the breakin process for a couple of thousand miles beyond that.
