M8 Dyno Numbers
The gas mileage at my first refueling stop was only 28 mpg, but that was attributed to the way I was riding. My next fuel stop was 32 mpg with a more reasonable hand on the throttle. I am collecting more data points on fuel consumption and hoping for 35 mpg during reasonable conditions. I just don't want to be the guy in the group that is always needing to stop for gas.
I included the AIM Light Force actuator in my build, and I would highly recommend it for you when your left hand start complaining. The friction point and reduced effort is really nice.
I agree with your assessment on the exhaust. Unobtrusive during steady cruise (even at 90-100 mph) and can really roar when I get on it!
What bike do you have and how about posting your dyno sheet. It'd be good to compare how these 124kits perform in general.
Concerning the clutch pull, I have a 2019 and was fine with the pull and engagement point before the kit install. FM didn't tell me that the pull would be stiffer and I didn't expect it -- all my experiences with AIM high performance clutch kits on a twin cam has been reduced pull. it's not bad, just stiffer like a twin cam cable actuated clutch. I've been reading about some of failures (seal leaking and loss of clutch) on the AIM slave cylinder so I think I'll hold off for now until that gets sorted out.
All in all I'm very satisfied with FM. How far are you from them -- I'm assuming you trailered there and back. I was surprised it only took them one day to do the build -- had it on the dyno that evening, and gave it back to me around 12pm the next day.
I live in Montana and it’s 1,200 miles to FM, so I started shopping for a local shop to do the build for me. My local dealer has never tuned with the PV and they were going through some personnel turnover in their Service Department so I rule them out. I considered a local independent shop with a good reputation, but they didn’t have a dyno so I called a neighboring dealership 152 miles away and talked to the Service Manager. I was impressed, they had a dyno and were familiar the PV for tuning and they had a good reputation for performance builds including turbo charged bikes making over 160 HP.
Basically, the FM chart that I based my purchase decision on showed a 2017 RGS making 154HP / 151 TQ, with nearly 140 TQ at 2500 RPM. I realized this was probably one of their best runs, so I tried to keep my expectations within reason. I replicated their build completely with FM 124 Big Bore Kit, Level A Ported Heads, Wood WM8-408 cam, SE 64mm TB with ported manifold, SE 5.5 msec injectors, AIM SDR Clutch with AIM Lightforce Actuator, Jackpot XXX 2-1-2 head pipe with Highroller mufflers and tuned with Power Vision and Target Tune. The only significant difference being the air cleaner, I went with the new FM / K&N High Flow Ventilator.
After watching everyone else's results, I was honestly expecting 145 / 145 +/- with 130 TQ at 2500. My build came in at 148 HP which was a good number and the peak torque came in at 136. I'm not really disappointed, and I have complete confidence quality of work done on my build. I was just expecting the torque curve to be maybe 5 ft/lbs higher across the rpm. FM tells me it can be the difference between a 6th gear pull and a 5th gear pull and that could explain it. The bike rides great and the power increase is very noticeable.
Full disclosure, for me this was sort of an exercise in validating the FM charts with results and this is what it is. I might call FM and ask if they think that air cleaner cost me some torque. I can’t help it, I’m just compulsively analytical.
Thanks for the heads up on the failures with the AIM slave cylinder, I’ll have to read up on those.
I live in Montana and its 1,200 miles to FM, so I started shopping for a local shop to do the build for me. My local dealer has never tuned with the PV and they were going through some personnel turnover in their Service Department so I rule them out. I considered a local independent shop with a good reputation, but they didnt have a dyno so I called a neighboring dealership 152 miles away and talked to the Service Manager. I was impressed, they had a dyno and were familiar the PV for tuning and they had a good reputation for performance builds including turbo charged bikes making over 160 HP.
Full disclosure, for me this was sort of an exercise in validating the FM charts with results and this is what it is. I might call FM and ask if they think that air cleaner cost me some torque. I cant help it, Im just compulsively analytical.
Thanks for the heads up on the failures with the AIM slave cylinder, Ill have to read up on those.
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
I would agree with this statement, admittedly our original 124 testing was done last year late fall/early winter in nearly perfect conditions. The numbers change here as well as the season & weather changes one extreme to the next. This is specifically why are transparently with the info we share and continually add charts to our dyno charts page to allow users to develop a common denominator on what they can expect from their build.
Great pipe but not for me in reality already spent mine too FM pipes, was going S&S 475 as keeping stock heads here, but waiting for FM new woods cam release, sounds like a lot of development in it,aready sent inlet manifold to Wards.
Be an optimised package for my set up
