M8 dry crank?
Thanks...
Thanks for reply
Thanks...
Thanks...
Anybody sitting on one that will sell? LOL
25400133
For the latest oil pump with comes with the gerotors, and the new pump seal plate, as well as the pump housing it's 62400247
If you are doing this, especially with a cam change, make sure to buy the spacer kit listed below, and might as well get the two new bolts (sprocket hardware kit) for a couple bucks more.
It would be adviseable to also get the cam bearing replaced since your are putting a new cam in. Harley sells the upgrade bearing but they don't make it so it's just easy to buy the same bearing without Harley stamped on the box.
You will have to have a couple tools, like the sprocket tooth locking tool and in your case the cam bearing puller. Both can be bought on Georges Garage. There are some knockoff tools on Amazon, that may do the job as well. Twin Cam locking tool is the same one you need.
https://www.georges-garage.com/produ...-locking-tool/
Here's the installer and then you need the puller as well.
https://www.fuelmotousa.com/i-238972...%20KING%20FLHR
https://www.fuelmotousa.com/i-218635...pull-tool.html
Did you ground the 2 outed plugs? Or just turn key and WOT with 2 plugs out?
Good news is my oil pump shipped.
