Hopping Harley
The reason the bike jumped is that the transmission oil is likely cold and thick preventing normal clutch slippage. Even if you had tranny-to-primary fluid migration (which was cured and the cure was built into the 2019's) that would not cause what you described.
I believe I read on a post somewhere that this was tied into sumping or fluid transfer, but could not find the post again.
Any help with this one?
Two follow-up questions: Was you 2019 affected by the clutch actuator recall, and if so, has the actuator been replaced? Do you have an aftermarket clutch actuator?
Exactly what I was thinking. Also, OP doesn't state mods, but if he has an AIM actuator installed, that has been known to leak and cause this as well.
I also notice that when it's cold out (<40F), the lurch is worse, presumably because of what other posters said - cold oil doesn't flow well. Finding neutral on a cold 114 isn't easy either, it usually takes a few tries to get it right, and the Neutral light doesn't even come on sometimes until the bike is running, gotta rock it back and forth to check.
Finally, with the stock oil in it, cold weather starts are much harder than warm weather ones - it even mentions this in the owner's manual. This can also cause problems - for me it's a "hard start" condition that requires a fully-charged battery to even start the bike when it's <32F out.
So, OP, wait until the spring, watch some videos on YouTube with HDs in them to get your vroom vroom fix, or actually go ride the thing once the roads are clear and dry
-John
As for pressure on the clutch plates, the hydraulic-actuation has no effect. Clutch plate pressure is mechanically controlled by spring selection.
Friction zone adjustments on a hydraulically-actuated clutch can only be accomplished by mechanical modification(s) upstream of the master cylinder that will change the stroke applied to the master cylinder, or by changing the displacement of either, or both, the master cylinder and the secondary actuator. There is no mechanical adjustment mechanism as you would find on a cable system.
Why?
Do you realize how much additional and unnecessary stress you are imparting to the starter system? Especially when cold.
