Hopping Harley
Old Jan 7, 2020 | 05:27 PM
Miclog's Avatar
Miclog
Default Hopping Harley
I have a 2019 ULTRA, and am having an issue starting it in gear. Even with the clutch pulled in, the bike jumps forward with the starter engaged.
I believe I read on a post somewhere that this was tied into sumping or fluid transfer, but could not find the post again.
Any help with this one?
Old Jan 7, 2020 | 05:30 PM
SWFLGuy's Avatar
SWFLGuy
If it’s just a slight lurch they all do that. If it’s more than that get it fixed.
Old Jan 7, 2020 | 05:38 PM
Miclog's Avatar
Miclog
We have a several feet of snow here, so I was in the garage, but the bike did not actually start, I released the start switch when it lurched forward. I will push it all the way back to the garage door and try it a little longer, and that should give me a little more reaction time
Old Jan 7, 2020 | 05:44 PM
Bass Player's Avatar
Bass Player
Start it in neutral . If it does it there you need a clutch adjustment.
Old Jan 7, 2020 | 05:46 PM
Keithhu's Avatar
Keithhu
Also, with multiple feet of snow, I presume you arent riding it. Why are you starting it?
Old Jan 7, 2020 | 05:52 PM
Miclog's Avatar
Miclog
I Put it in neutral and it started right up. Shut her down, popped it into first gear, started her back up, there was a slight lurch, and then she started, and stayed still.
All is well, but for the winter blues....
Thanks, Gentlemen.
Old Jan 7, 2020 | 05:56 PM
Miclog's Avatar
Miclog
I got spooked by several posts, and have been going over everything. I noticed that there was a switch issue that did not allow some bikes to start in gear, so I wanted to check it out.... Plus I cannot seem to keep from jumping in the saddle and making vroom noises, lol...
Old Jan 7, 2020 | 05:58 PM
Keithhu's Avatar
Keithhu
Yeah, not good to start the bike in the winter if you cant get it up to operating temp. I understand the temptation tho. I'd say just let it sit until you can ride it to the dealer and have them check it out. If it needs adjustment, its a warranty issue.
Old Jan 7, 2020 | 06:18 PM
UltraZac's Avatar
UltraZac
It's a 19, so there is no clutch adjustment. My guess is it's cold, so the clutch discs were stuck a little with the cold oil. Running it in neutral flung the oil off the clutch. Starting again with clutch pulled would stop the lurch because there is less oil between the clutch discs.
Old Jan 7, 2020 | 06:33 PM
mjwebb's Avatar
mjwebb
is this not a symptom of the clutch actuator recall? or would all 2019s have been exempt?
