RDRS Rain Traction Control setting
Old Jan 20, 2020 | 06:41 AM
mjwebb's Avatar
mjwebb
Default RDRS Rain Traction Control setting
so coming up a slight uphill section of straight highway that was wet yesterday I was in the process of redlining it in 4th gear and the TR lamp flashed until I backed off the throttle to shift to 5th. so it came on somewhere between 4500 & 5000 rpms and was over 80 mph ...surprised because this is a bone stock 114 and I would never expect it to come on in this scenario..wonder if it's perhaps programmed overly sensitive, maybe if it was in standard TR instead of Rain it wouldn't have, maybe the OEM Dunlop is just a bad wet conditions tire, or there was a slight uneven bit of highway that lifted the tire up enough......anyone else have personal observations with their TR?
Old Jan 20, 2020 | 07:08 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
My 2017 of course does not have it and I have not ridden one of the new ones yet. But I am interested and think that these advancements certainly add a new level of safety.
Just an observation and in no way criticism. I Seldom see 4 k RPM or over. In wet road conditions I apply my own traction control by staying in a higher gear and keeping the revs lower. As for Dunlop’s my personal opinion of them in wet conditions is very good. I have several thousand miles of safe travels in heavy rain with them. Keep in mind you have a small contact patch.
To me it sounds like the system is working! Thanks for posting so we can all learn and get a better understanding of the system.
Old Jan 20, 2020 | 07:19 AM
mjwebb's Avatar
mjwebb
yeah, I don't run around redlining it everywhere I go either..
this was just one of those times being able to get out with cabin fever since the weather has been horrible...it wasn't raining at the time, there was no traffic, didn't 'see' any cops and seriously needed to blow the cobwebs out of my bike, and mind
edit: so my takeaways from this experience are:
1. it does appear to be working as intended / designed
2. the stock 114 is not an underpowered slug
3. I will always enable Rain mode when roads are wet
Old Jan 22, 2020 | 08:31 AM
saddlebag's Avatar
saddlebag
I never put it in Rain mode. I find the tire will spin a little in normal mode but the system works well at taming it very gradually...or maybe it's just me rolling off the throttle. I dunno, but it feels natural not jerky or obtrusive. The other thing I really like is the way HD tames the rev limiter. It feels pillowy when it's hit. No harsh engine braking or anything. Very well done IMO.
Old Jan 22, 2020 | 08:54 AM
VDeuce's Avatar
VDeuce
The Dunlops have a very hard compound and are really not that great in the rain. If you swap to another brand, you'll notice this in the wet.
Old Jan 22, 2020 | 09:52 AM
KrustyKush's Avatar
KrustyKush
I've not used anything but the stock type Dunlops on mine. I had a step-out happen with an easy throttle roll-on on wet pavement, 60 degrees f, in 5th gear, at 70 mph. The step-out on the rear wheel was a major event that caused my pants to get dirty. I wish I had RDRS! Nowadays I don't ride much in rain, but when I do, I don't do very much "rolling-on."
Old Jan 22, 2020 | 10:06 AM
mjwebb's Avatar
mjwebb
makes sense with the MT center tread being harder for wear longevity...I'm feeling really good about having RDRS now despite somehow having survived 15 years without it
Old Jan 22, 2020 | 10:35 AM
Wmitz's Avatar
Wmitz
I went thru a couple of corners at a faster pace then I should have, when powering out of them hit some ripple bumps the rear slid a bit, the rdrs/tc reduced the throttle action and let the bike stabilize quickly. No long lasting effects, was back to normal in a couple of seconds or so. Dry pavement though.
Old Mar 1, 2020 | 10:32 AM
Breizh Rider's Avatar
Breizh Rider
Default TC solution for non equipped bikes
This will be my first Harley (Low Rider FXLR).
HD softails have plenty of powerful torque. When the road is wet and/or muddy, TC is not a gadget in my opinion.
I would have liked to be offered the option of installing TC on mine. Same as the Cruise Control available kit.
Softails got ABS (standard in Europe), Ride by Wire and an on board computer. I think it should not be complicated to
implement a TC solution for bikes like mine.
Old Mar 1, 2020 | 02:54 PM
Kyle Moore's Avatar
Kyle Moore
That computer in your bike can probably detect wheel slip well before you can feel it, it’s comparing the wheel speed of the front and rear wheels most likely and calculating a slip percentage. Sounds like the system was workin to me. I really wish my bike had the cornering ABS etc. considered trading up to get it. I think if H-D can figure out how to get these systems on the bikes to get new riders in em I’m all for it. I am 100% opposed to an automatic or automated transmission but I’m sure that’s coming. If it gets people on Harley’s I'm ok with it as long as i am not required to buy it.
