I have a 2019 Tri Glide so oil hot bike level let it idle for 1 min after a long ride, check level after 1 min oil is at 2 dots above the add mark upright. I have decide to bench the A-1 Ventilator as I see no purpose for it on my bike as it pukes no oil through the external breather I have installed. The A-1 was installed correctly over the rear cylinder and set on top of the throttle body Thanks for the replies
First of all, your bike does not need to be ventilated at the oil tank, and if the manufacturer tells you that it works if you add less oil, then it’s probably just some BS to waste your money on.
