Ok, so I've lurked long enough, done as much digging as I can and I've come up with a few questions. So I've got a 2017 RKS 107 M8. I think I've decided on the FM jackpot 2/1/2 headers, and the rinehart motopro 45s. My bike currently has the stock headers with cats and the S&S MK45s, and I really don't like the sound. Going with the power vision tuner as well. Anyways, I've loaded up my cart on the FM site, but i'm a little hung up on the air cleaner. I love the look of the rinehart inverted air cleaner, but haven't been able to find much on here about it. Sounds like a forum fav is the SE heavy breather, which I do like the look of too. Just curious as to any benefit of one over the other, or if most of these are a wash. I called FM and they obviously suggest the FM AC/DC intake, which I'm not entirely opposed to either, but just love the look of the rinehart inverted. As for future plans, I have no plans to go any further than a stage one ever. Don't see the need for it for myself. Thanks for the help!
Something to check on is what kind of bolts are used to secure the AC backplate to the throttle body. Some AC's don't use self capturing bolts. The reason is that you must make sure you use Loc Tite on the non capturing bolts because if one of them comes completely loose it can get injested into the engine. The AC's with captured bolts don't have this concern.
for a Stage 1 there is no performance benefit of one high performance AC over another..they will all allow more air than needed..heck the SE AC kits were designed for Stage 1 through Stage 4..not until recently did they introduce Elite or Extra HP ones for builds with power up to 150 HP+ as advertised..get the one that you like best but be aware some may be noisier than others and 'leakier' than others so do your homework on those things
Yep for non captured bolts, make sure to use blue loctite and torque appropriately. I went a step further and with a tiny modeling brush put a thin paint line from the bolt to back plate. This creates an quick visual on whether any of the bolts are backing off. After 10k miles and periodic inspections, no signs of backing off. Got this idea from this someone else on this forum. Having said that, if you put enough loctite on and allow 24 hrs to cure, even after breaking the bolts loose by wrench, a good amount of effort is needed to take out the bolts.
Another thing that may save you some coin would be to take 30 mins and decat your stock header, at stage 1 it will perform just as well as an aftermarket header but still get rid of the heat, also save you about $500-700 that you could spend elsewhere.
not intending to turn this into an oil thread...but I'm under the impression (and knowledgeable folks please step in to correct me if I'm wrong) that when doing away with Catalysts one should use an engine oil with more zinc which offers better overall engine protection, because the only reason for using oils with reduced zinc was to protect the catalysts..???
If I can ad, before you spend the money on new slip-ons because your not a fan of the MK-45's sound, put the new head pipe on or even as just mentioned decat your existing head pipe and listen to the MK-45's again. The Cat head pipe is whats making it not sound good.
Thanks for the feedback. One more question I had regarding the air cleaners. I looks like some mention a breather tube and some do not. For example the Arlen Ness big sucker mentions it, and the Trask does not. How important is this? Any real benefit or is it a gimmick. Thanks again
I debated this, and would for sure save some coin. These MK45s have a good low rumble, but I really like that crack of the rineharts. Ive done much YouTubing with and without cats on both set ups, and I think I prefer the rineharts.
