How barebones can a M8 softail get?
Old Apr 11, 2022 | 01:57 AM
OZRap's Avatar
OZRap
Default How barebones can a M8 softail get?
Obviously a newbie. Go easy on me. Hear me out
One of the major reasons people love shovelheads, Evos, etc. imo is prolly simplicity and the mostly 'mechanical' aspect of the engine. You can just remake and replace mechanical parts are the bike will survive.
They are not the most efficient but at least you dont hear "idle rpm has to be over x00 or the oil pump wont be sufficient and the bike will blah blah.. hence the efi rpm during idle'. This gets me thinking how much of the electronic are mandatory.
Let's say a M8 non touring bike, like a softail standard with ECM, BCM, IM and so many sensors and electronic functionalities...
If you wanted to turn your M8 softail into simpleton bike down the road, what are the bare minimum electronics and/or electrical setup that would still the let the motor and bike function?
Wise answers to a dumb and imprecise question would be much appreciated!
Cheers
Old Apr 11, 2022 | 02:45 AM
Jackie Paper's Avatar
Jackie Paper
It's not oil. If it didn't idle in that range, there would be times it could die because it could not catch itself .
It needs it all. It's all interlinked.
Make your second post over in the new member area.Welcome from North Beach, FL., USA!
Just in case you have not done this.
Add a Signature Line in your USER set up for your bike year, model, and all the letters that Harley recognizes it with so others see at the bottom of all your post. This enables others to know your exact model if you ever ask a question.
And a Avatar of your favorite shot in the USER set up for the small picture others will see in the top left corner of your post.
​​Your all set.... Enjoy the ride! ______________
Old Apr 11, 2022 | 05:53 AM
Keithhu's Avatar
Keithhu
http://www.amm.haan.de/Milwaukee-Eight/M8.htm
Old Apr 11, 2022 | 06:31 AM
IronAss's Avatar
IronAss
Originally Posted by Keithhu
That right there could make me a fan of the newer bikes.
Old Apr 11, 2022 | 06:38 AM
smitty901's Avatar
smitty901
Seems you have fallen for a lot of misinformation.
Old Apr 11, 2022 | 07:13 AM
ThePaintPirate's Avatar
ThePaintPirate
Uh, correct me if I'm wrong but I think you hear that a lot.
Old Apr 11, 2022 | 07:22 AM
IronAss's Avatar
IronAss
Originally Posted by ThePaintPirate;[url=tel:20551911
20551911]Uh, correct me if I'm wrong but I think you hear that a lot.
This^^^
Low idle is hard on big end rod bearings regardless of the which engine it is.
Old Apr 11, 2022 | 08:05 AM
OZRap's Avatar
OZRap
Thumbs up
ooops! thanks for the comment and the heads up.
Will post next on the other board as you suggested .
Old Apr 11, 2022 | 08:47 AM
wannavee's Avatar
wannavee
that bike running
Old Apr 11, 2022 | 08:05 PM
OZRap's Avatar
OZRap
Originally Posted by wannavee
Only saw the video before on youtube but i can now see i how detailed the guy described the whole ordeal. Thank you for the info!
