Oil Pump Seal Replacement?
Old Nov 1, 2022 | 06:37 AM
Lammy1000's Avatar
Lammy1000
Default Oil Pump Seal Replacement?
2020 Softail 107ci, 25,000 mi. I am in process of installing WM8-22X cam. Should the oil pump seal #62400205 be replaced? Oddly, it was not included in my Cometic cam change kit. Yes, the factory manual has it being trashed, but none of the research mentions replacement.
Old Nov 1, 2022 | 10:17 AM
FranBunnyFFXII's Avatar
FranBunnyFFXII
Veteran: National Guard
I assume it may be a lot like the O-Rings in the engine case, that the Oil pump mates with, crushed down for that seal.
I would replace it if it's recommended too. What's it cost? 2$?
Old Nov 1, 2022 | 11:28 PM
Kiwirob's Avatar
Kiwirob
When you pull the camplate and cam, the oil pump should stay put, should be no need to pull it. 2020 Softails have the new improved oil pump, if you're interested. - Rob
MRPHS
Engine Mechanical Topics
Nov 25, 2022 03:38 PM
quizzicalchimp
Milwaukee Eight (M8)
11
Dec 30, 2021 10:12 AM
riley drake
General Topics/Tech Tips
Jan 22, 2011 05:41 PM
77Tulsa
Jul 10, 2007 04:18 PM
AK_Hog_Herder
Oil Archive (no new posts)
May 6, 2006 08:33 PM
