Fuel Pumps
Old Mar 30, 2024 | 10:47 AM
sbeamer's Avatar
sbeamer
Default Fuel Pumps
from experience, what brand of replacement fuel pump would you use in the M8 ? AND, does anyone know how much pressure it is supposed to have ?
Old Mar 30, 2024 | 10:55 AM
mjwebb's Avatar
mjwebb
why not just use the OEM?..since being a regular here since the M8 came out in 2016 and on my 3rd one, I have read and heard of practically every problem, chronic or isolated and fuel pumps are one thing that have not been reported as concerning or problematic
Old Mar 30, 2024 | 11:00 AM
rigidthumper's Avatar
rigidthumper
Should be 4 bar (~58ish PSI), and factory is adequate unless you're running E85 on a huge engine. If you go aftermarket( like Fuelpumpfactory, or AEM), be sure to wire in a relay, so the BCM doesn't shut power down to the pump ( different current draw from stock).
Old Mar 30, 2024 | 03:02 PM
Redrodyankneck's Avatar
Redrodyankneck
I was with you on the 1st sentence, lost me after that.
Old Mar 30, 2024 | 03:30 PM
NorthWestern's Avatar
NorthWestern
Did yours fail? Curious about the symptoms, etc. This is the first one I had read about, other than issues related to a filter never being changed.
Thanks!
Old Mar 30, 2024 | 06:22 PM
mjwebb's Avatar
mjwebb
if I have to explain you wouldn’t understand
Old Mar 31, 2024 | 07:48 AM
sbeamer's Avatar
sbeamer
No, mine didn't fail,(I think). I have a post started elsewhere on this forum; Pop/bang. Haven't got much traction on it. But the fuel pump is the only thing I have not changed it the WHOLE fuel system. (mechanically speaking). If it's not the fuel pump, then it would have to be something electrical, and that is where I give up. I don't know how to diagnose electrical. so I don't even start.
Old Mar 31, 2024 | 07:58 AM
NorthWestern
So, you have not tried a different tune, yet?
Old Mar 31, 2024 | 01:15 PM
FLTRI17's Avatar
FLTRI17
Stock pump works fine. No need to experiment with aftermarket parts.
Bob
Old Apr 1, 2024 | 08:28 AM
sbeamer's Avatar
sbeamer
I did try mulitple tunes at the end of last years riding season. No difference.
