I remember reading somewhere here couple of days ago, where someone stated that fueling did not recommend the use of S&S lifter cuffs with the fueling lifters.
I checked both of their websites and there's no mention of any compatibility issues.
Is this a thing?
Memory loss? Yea, its something that we all have, especially as one ages
Paraphrasing here: The aftermarket metal cuffs can wear from the lifter rubbing against it sending metal down the lifter bores and into the cam chest.
No longer recommended until Feuling finishes their redesigned cuff (coming out sometime?).
It was mentioned in a Thrashin Supply video when they were upgrading a motor with Feuling's help. Specifically said by the Owner of Feuling (Luke Leatherman).
At first it was a 'thing' with the lifters that eliminated the roller bearings for bushings.
My guess is that Fueling selling oversized lifters that there was an interference problem there.
I sell +.002 lifters & I know they only work with the stock cuffs.
Thanks, guys...
I'm going to assume they don't recommend using the metal cups with oversize lifters specifically, which would make sense.
As far as using them with standard size lifters, I asked them, finally got an answer "the cuffs SHOULD work BUT fitment is not verified" Lol. Should, could, might
I just remember reading something about somebody saying there was an issue and I wondered what the specifics were. People have been using S&S cuffs without any issues with all kinds of different lifters. They do recommend using shims to center the cuff before tightening down, to avoid any contact with the sides. That could be a wear issue if you didn't do it.
Isn't that the reason when installing metal lifter cuffs you're supposed to put the feeler gauge between the lifter and cuff before final torque to ensure you maintain clearance?
Literally just said that, yes that is the reason......
"They do recommend using shims to center the cuff before tightening down, to avoid any contact with the sides. That could be a wear issue if you didn't do it."...
OK, just because this is the first M8 that I've kept, (got rid of two 17 RKS for tranny fluid transfer), I'm just now getting into this M8 motor, per se. I looked up some lifter cuffs to see what we're talking about here, and have a question. If the cuff doesn't touch the lifters themselves to like help guide them or something, what is their exact purpose? To keep the lifters from flying out of their assigned lifter bore? Just curious...........
To keep them from rotating. Under normal conditions it's not a problem. An example is loss of valve control where the lifter is dancing around in there the cuff keeps them straight.
The lifters need to be kept in position so that the rollers are aligned with the cam, the same thing the roller pin under the lifter covers does on a TwinCam. The plastic cuffs work fine. I've been following the M8 forum since 2017, I can't remember anyone ever reporting a failure (and yes Funnel, I'm 71 years old and memory loss is a thing), but still, I don't think it has ever been reported. Chevy uses plastic lifter guides and I haven't heard of them failing either. I don't think anyone is offering aluminum guides for Chevy's, but I don't follow anything that would give me that information. I've seen where Steve Cole has posted he doesn't recommend the aluminum lifter cuffs unless you are using a really high lift cam. Not sure how high, but I think it was more than .540 lift. The FLTRXRRSE 1TPV CVO ROAD GLIDE RR (2025) has the SE8-550 cam (.550 lift) from the factory, and it still uses the same 17900034 and 17900035 LIFTER ANTI-ROT CMPNT,X that the earlier models came with. I think if it is good enough for the most expensive factory model Harley offers, it will work for me.
