Ordered the Header Breather System from DK Custom
Old Nov 22, 2016 | 04:25 PM
silveradoman2's Avatar
silveradoman2
Default Ordered the Header Breather System from DK Custom
I just ordered the Discrete Head Breather for my ride. It should hopefully save the engine life. Thanks DK Custom.
Old Nov 22, 2016 | 05:39 PM
Mchad's Avatar
Mchad
I've done it to the last 4 air cleaners on my own. I like to think the motor is happier venting externally.
Old Nov 22, 2016 | 06:00 PM
silveradoman2
I have been reading a lot of threads about this. What the internal parts of the engine looks like due to the oil and or other byproducts that go through the TB. I have 4,300 miles on her now and would like her to last as long as I can. They're telling me I should see it Monday. I still have the original Breather bolts with the nipple on the tip. Should be an easy install with the SE High Flow A/C. I am stoked.....
Old Nov 22, 2016 | 06:35 PM
silveradoman2
MChad several people go as far to say you only have a problem of excess oil through the Head Breather, when you overfill the oil. Well I know for a fact that when my 01 Indian Scout, which has the S&S 88 in it, she will leak a milky oil substance on the ground when I let her sit for a couple of weeks in the cooler weather. Moisture gets in the engine and when it warms up it kinda bubbles out of the head vents. On the Indian it drips on the floor. HD has the problem with the EPA so they can't do it. My brother has a 2000 CVO SERG. His also funnels into the A/C and drips oil from the cover. He has 50,000 mile on it. If he keeps it I will do the 50,00 service and change his system as well. Would be even easier, all I would need is the filter. But he is looking at a 17 or 16 RGU. So I may not have to do anything to the 2000, since he would trade it in.
Good chatting with you
Old Nov 22, 2016 | 07:34 PM
silveradoman2
I am even going to do an Auto tune again with my FP3 and apply learned avlues about 3 times. I wouldn't doubt it would even be better. Again I am so happy I did the little investment.....
Old Nov 22, 2016 | 10:04 PM
RG Pilot's Avatar
RG Pilot
An external breather is a good idea but don't overthink it. I kinda doubt the credibility of the two pictures shown with and without a breather at 8,000 miles. Don't get me wrong, I did a breather too but I doubt that it works miracles. BTW, I did an auto tune after adding the breather too but I also had taken off my SE intake and put the stock one back on but with a K&N element. I couldn't tell the difference either. I didn't like the induction sound with the SE intake.
Old Nov 22, 2016 | 10:31 PM
sixguns's Avatar
sixguns
1000's of bikes run as they came out of the factory without issue. The aftermarket makes 1000's of dollars off the rest. Everyone makes their own way through this life of ours.
Old Nov 23, 2016 | 06:55 AM
Mchad's Avatar
Mchad
It gives me something to do to new bikes...
I picked up a cheap-o drill press from Amazon, which makes it really easy. That for the hose barbs to vent. I tap and fill the internal vent holes to the TB with a 6mm set screw secured with oil resistant red loctite. As an extra step i fill the same vent tube from the top side with JB weld injected through a curved syringe. Never liked the idea of any oil sitting on top of the set screws, oil resistant loctite or not...
Here's one I did to an Arlen Ness Big Sucker
And a HD Ventilator
Most recently did it to my Heavy Breather on my LR-S.
Old Nov 23, 2016 | 08:53 AM
crimson13's Avatar
crimson13
What size barbs are you using, drill bit and tap also ?
I used a zippers back plate and oem rushmore vent hoses to route mine. I am wanting to get a SE Heavy Breather and would like to vent it like yours.
Thanks
Old Nov 24, 2016 | 06:50 AM
Mchad's Avatar
Mchad
Thanks
I use 3/8" stainless barbs with 1/8" NPT threads, and a 1/8" NPT tap of course. To tap and plug the breather channels I use 6mm by 12mm long set screws and a 6mm X 1 tap.
The 1/8 NPT tap needs 11/32 bit, and the 6mm set screw needs a 5.2mm bit.
These are the parts I used:
Barbs
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Set screws
Syringe to "inject" JB Weld
https://www.amazon.com/Syringe-Only-...Curved+syringe
And Loctite 263 (high strength - oil resistant)
https://www.amazon.com/Loctite-13305...ds=Loctite+263
All that stuff, some 3/8 fuel line for the vent, and last but not least something for the end...
Chrome
Black
That should cover it.
Some tips. Measure fifteen times! I ruined a backplate on my LR-S because I forgot about the TBW servo sticking out. You have to angle the barb to the back of the bike about 15-20 deg from vertical to clear it. No worries on the front.
Other then that, a drill press and a vice is highly recommended. Any questions, pm me. I've hijacked this thread enough! Sorry Silverado! (GREAT movie btw, if that's where it comes from)
Edit: to add, the breather channels that I tapped, don't need the drill press. A hand drill just to get the hole wide enough for the tap to grab, and you don't even need to if you muscle the tap in enough to grab. Just keep inward pressure for the first 1/4" or so.
