Oil Archive (no new posts) An archive of oil related questions and comments.
Engine oil in Primary
Old Feb 2, 2023 | 04:06 PM
lakers9657's Avatar
lakers9657
Default Engine oil in Primary
Hey guys, I have read some conflicting information around using engine oil,
specifically 20W50, in the primary and transmission casings. I understand there’s a recommendation to use different oil in each, however, some sources are saying it is fine to use the same oil in all three. Thoughts?
Old Feb 2, 2023 | 04:08 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Follow the recommendations in your owner's manual.
And if you post over in the Oil forum, you may get more response, just saying.
https://www.hdforums.com/forum/oil-a...ted-topics-30/
You can thank me later.
Old Feb 2, 2023 | 04:14 PM
Rusty Springs's Avatar
Rusty Springs
There are lots of options and opinions. Most aren't wrong.
Old Feb 2, 2023 | 04:27 PM
702's Avatar
702
Welcome to the Forum.
The members here really like oil questions, especially in the winter. BTW, when you park your bike in the garage do you lock the forks?
Old Feb 2, 2023 | 06:42 PM
Ghetto blaster's Avatar
Ghetto blaster
I like to use extra virgin olive oil in mine, the kind made by real virgins uh thank you, but seriously, not saying this is what you should do, but I use elcheapo Shell 20w50 in all three holes, never had issue, put 80+ thousand miles on a sporty using the same oil in motor and primary, also 0 issues.
Old Feb 2, 2023 | 07:09 PM
PureHybrid's Avatar
PureHybrid
The key is to get an oil that won't make the clutch slip. Look for the Jaso MA / MA2 label and it'll be fine
Old Feb 2, 2023 | 07:22 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
When you put gas in the gas tank, where do you put the gas cap? It's already been mentioned but go to the oil subforum and think about what you want to use where. By the way do you wear fingerless gloves?
Old Feb 2, 2023 | 07:23 PM
Highway Handler's Avatar
Highway Handler
If you want to live on the edge, you could follow the manufacturer’s recommendations.
Old Feb 2, 2023 | 07:52 PM
roussfam's Avatar
roussfam
Subscribed
Old Feb 3, 2023 | 07:55 AM
mjwebb's Avatar
mjwebb
either way is fine..if you do go the three different specific formulas route...make sure not to put the primary fluid in the engine, or the engine oil in the transmission or the transmission fluid in the primary ... and don't ever put blinker fluid in the gas tank instead of stabilizer..that about covers fluid recommendations
