Oil Archive (no new posts) An archive of oil related questions and comments.
Changing Oil Cold
Old Mar 14, 2023 | 11:19 AM
  #31
hd4evr2008's Avatar
hd4evr2008
Thanks everyone. Just to add, the bike had an oil change last May, and only has less than 1,000 miles on it since then. Yeah, I know, but I had some ruptured discs in my neck last summer and couldn't ride for a couple months. So, anyway, I'm thinking I'm gonna ride it a few miles before I change it, and do it warm. One of the reasons I wanted to change it soon is because I have a couple open quarts of Mobil One that were left over from about a year and half ago that I wanted to get in the engine before it went bad. How long will open bottles of oil be ok to use?
Old Mar 14, 2023 | 11:42 AM
  #32
Rounders's Avatar
Rounders
I would not even change if only 1k miles, unless lots of short trips where not getting hot.
You are draining from oil pan not engine on new big twins. Cam chest and bottom end has oil left in it, and cooler if you have one.
Old Mar 14, 2023 | 11:45 AM
  #33
hd4evr2008's Avatar
hd4evr2008
Sorry.....should have posted this the first time. It's a 2006 Electra Glide Classic....35,000 miles.
Old Mar 14, 2023 | 12:15 PM
  #34
PureHybrid's Avatar
PureHybrid
Well in that case I vote to not change it at all, your open bottles of oil will be fine.
But changing it cold won't hurt anything
Old Mar 14, 2023 | 02:30 PM
  #35
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Change the oil when the oil has 5,000 miles on it.
Don`t change oil because you have the urge to tinker.
I agree with Ron, pull the battery, clean the posts and battery cable contact surfaces, and the surfaces they connect to.
Clean the starter relay contact surfaces.
While the battery is out, take it to an auto parts store and have it load tested.
Check the air pressure in the tires.
Check the moisture content in the brake fluid.
Have you inspected the cam chain tensioners?
Old Mar 14, 2023 | 02:41 PM
  #36
TUCCI's Avatar
TUCCI
Just fire it up and run It till the casing feels hot to scalding , then shut it off and drain it out. I've done plenty of late in the season snow on the ground service calls on bikes and that's how I handle it. Cold is not necessary and neither is having to run it for a few miles.
Old Mar 14, 2023 | 02:42 PM
  #37
CaffeineBuzz's Avatar
CaffeineBuzz
it's a small thing to warm it up, the service manual says to do it, so I do it
Old Mar 14, 2023 | 02:48 PM
  #38
gonemad's Avatar
gonemad
I changed mine last week. Warmed it up good first like the FSM says.
Once I had the filter off, cleaned up the mess I make... repeatedly...every time, it was now cold.
I think I’ll just start cold next time.
Old Mar 14, 2023 | 02:56 PM
  #39
CaffeineBuzz
so it got cold before you put oil back in it?
i'm curious, where in the manual does it warn you not to do that? I'm confused
Old Mar 14, 2023 | 02:59 PM
  #40
hd4evr2008's Avatar
hd4evr2008
Battery... Checked
Air pressure.... Checked
Brake fluid... Checked
Tensioners.... Already replaced
It's supposed to be warming up in the next few days. Changing it tomorrow. Cold. Thanks for all the replies!
