Oil Archive (no new posts) An archive of oil related questions and comments.
oil cooler
Old Feb 16, 2008 | 07:25 AM
newbob's Avatar
newbob
Default oil cooler
Does anybody know if the cool collar oil cooler that I am seeing on EBAY really work?
Old Feb 16, 2008 | 10:22 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: oil cooler
I think those are a waste of $$. If you are not running synthetic oil then I would spend my $$ on syn oil instead.
Old Feb 16, 2008 | 11:03 AM
newbob's Avatar
newbob
I remember seeing them at my harley dealer years ago,I guess they dont sell them anymore.
Old Feb 16, 2008 | 08:55 PM
bobcowan's Avatar
bobcowan
That's not really a cooler, it's a heat sink. They do work, but they need to be installed correctly. I'v not seen any for a harley (or any motor vehicle)that would actually work.
A heat sink removes heat by conduction. The hot object (oil) must be in direct contact with the heat sink. Even a small air gap will insulate it enough to be almost useless. If you packed the heat wink with the proper grease, then put it on the oil filter, it might actually work.
Old Feb 16, 2008 | 09:04 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
They work but not like he advertises. Look at the conditions he describes, a 70 degree day. On my 02 FLHT I would cover my oil cooler at 70 degreesso the oil would reach proper temp, on a 70 degreeday you don't needa cooler. I used one of those collars on my softail and on a 95 degree day it reduced the temp in the oil tank 4 to 5 degrees. They help but very little when you need it the most.
Old Aug 19, 2008 | 10:02 PM
pjpockets's Avatar
pjpockets
Default cool collar.
I talked to the man that is putting these out. His words are that the oil goes through the engine back to the holding tank so the oil gets heated up again. The oil actually going out of the filter is cooler by around twenty degrees then oil going in. But what you see at the tank guage may only be about 5 degres. The only way to really know is to somehow measure as soon as possible after the filter.
Old Aug 20, 2008 | 03:38 PM
quigley's Avatar
quigley
This works much better at keeping your engine cool......
http://cgi.ebay.com/ebaymotors/ws/eB...m=150283433296
Old Aug 20, 2008 | 03:45 PM
Bluesssman's Avatar
Bluesssman
He is feeding you a line of bull! If it worked as he claims, thousands and thousands of Harleys would have them installed!
Old Aug 20, 2008 | 11:06 PM
pjpockets's Avatar
pjpockets
Default test
I am having him send me one and will try it out on the 07, and let every one know what it does. Its really just a test. Im also going to fit it on with heat sink grease, to get as much out of it as possible. Now all I need is for the heavy rain to go away hear in WA.
Old Aug 21, 2008 | 04:44 AM
sporty2003's Avatar
sporty2003
using synthetic oil and a reg oil cooler will do wonders for your bike . and it will quiet it down alittle . you get a cooler with a thromostat.it will put it a better range. these new motor's run real hot anyway.but to me way to hot.
