I have a '98 FLSTC Evo with carb. I just put a temp gauge type dipstick in my oil bag and was just curious as to what I can look for with regard to a normal oil operating temp range. I ran it yesterday for about an hour and the oil temp was approx. 175 degrees. Air temp was about 65 outside.
Do you guys know what the hottest temp your oil should get to before it's considered a problem?
In the TC engines which run hotter than the EVO's when you reach normal operating temps on a hot day, Anything much over 250+ should be the candidate for a cooler and possible some sort of attention to fuel remaping as it is probably running lean and complication the issue.The evo's usually run around 200* plus or minus as a rule. TC engines run comfortable between 200-250 * depending on conditions. Much above that will damage the engine oil especially if it is not synthetic. The breaking point for dino oil is around 250* where as the synthetic oil can tolerate 300*. Not good in any case but can make a difference. Engine ignition timing in the evo's can make a difference in temps also.
My bike runs about 180-200 deg during the summer months.
When stuck in shore traffic it goes up. Am going to install a cooler on it.
Anytime it gets to hot (over 240) i do an oil change. Oil is cheap.
A modified motor cost MONEY to replace. IMHO
