Oil Archive (no new posts) An archive of oil related questions and comments.
HD Formula +
Old May 10, 2009 | 08:05 AM
mcdaniel52761's Avatar
mcdaniel52761
Default HD Formula +
I did a search on the forums here, and there hasn't been a posting on Formula + this year. So, with Harley saying to use Formula + in their 09 cruise drive transmissions and *most* of the previous postings from 06-08 saying to use something different.....I was wondering if people who have the cruise drive transmissions are using Formula + or something different and if their opinion on it has changed? If you look on the Amsoil website, you get 75-110 in the transmission and the 20-50 in the engine and primary while alot of people use 75-90 Mobile1 in the transmission. I'd like to know what to use since there are A LOT of posts on here about people having transmission, primary and engine issues.
Old May 10, 2009 | 09:22 AM
dynarule's Avatar
dynarule
Use a GL5 gear lube of your choice. The F+ is great for the primary but thats about it. If you go to BITOG you can find a VOA on the F+ and there isnt much of anything in it.
Old May 10, 2009 | 09:58 AM
Heath's Avatar
Heath
Former Sponsor
If you use gear lube in the tranny go with either a 110 or 140. The 90, in amsoil's case anyway, is a lower viscosity than the 20/50 oil. The 110 is the same as the 20/50. Amsoil actually recommends the oil in all 3. The 20/50 oil is cross referenced product for the formula +.
All will work, just a personal preference.
Old May 10, 2009 | 02:32 PM
mcdaniel52761
That being said, what is the difference between using 20/50 or 110 in the tranny?
Old May 10, 2009 | 02:52 PM
Heath's Avatar
Heath
Former Sponsor
There should be no difference as far as lubrication and protection, but many say that the gear lube makes things a little quieter. That may be because they are running a 140 weight in most cases but some with the 110 have noticed it. I've always used the 20/50 in all three, but I'm gonna try the 110 next time just to see if I notice a difference.
Old May 10, 2009 | 04:55 PM
Bill G's Avatar
Bill G
I use Formula + just like the manual says in my 09 SG in the trans & primary and it works just fine, nothing wrong with it at all, I also used it in my 07 with no problems. The Formula + was designed for the new cruise drive transmissions, but I am sure there will be diffrent opinions about what is best from all the oil Doctors He He!!!! no offence, just kidding guys. The Formula + will works fine in the trany & Primary.
Ride Safe,
Bill G
Attached Thumbnails HD Formula +-harley-pics-all-done-019.jpg   HD Formula +-harley-pics-all-done-017.jpg
Old May 10, 2009 | 11:03 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Formula+ is a 50w oil with a fair additive package. It will work but a GL5 75w140 gear oil will work better for the same money or less. Gear oils are more shear stable than a 20w50 in a transmission application.
I use Redline Shockproof Heavy gear oil which is a 75w250. It will go 20,000 miles easily. The cost is about $10-11/qt. I run it 2 years. So it is cheaper than Formula+ and really quiets the trans.
Old May 11, 2009 | 03:11 PM
Black Bart's Avatar
Black Bart
I use Formula + in my primary only and a 85W/140 gear oil in my transmission.
Bart
Iwanna
2014-2024 Touring Models
43
May 18, 2016 09:49 AM
steelerdude1
Jul 19, 2011 08:21 PM
cruzmisl
Aug 23, 2010 08:20 PM
rmarion
Jun 18, 2007 02:06 PM
Johnny B Good
Mar 7, 2006 02:40 AM
