Oil Archive (no new posts) An archive of oil related questions and comments.
Oil cooler adapter
Old Jun 16, 2010 | 03:52 PM
wbogan's Avatar
wbogan
Default Oil cooler adapter
I have a '01 Road King Classic. I purchased a Harley Davidson brand oil cooler kit from Harley. I have followed the instructions carefully installing it on the bike. I have installed the adapter with proper alignment of the gasket twice, once without permatex and once with permatex. Both times it leaked like crazy. Yes, I tightened to proper torque specs.
Has anyone else had this problem? I am baffled!!
Old Mar 20, 2011 | 02:42 PM
Jakesy's Avatar
Jakesy
Stage III
I'm having the same problem right now. Did you have any luck? Did it work out? What did you have to do?
Thanks
Old Mar 20, 2011 | 03:42 PM
$tonecold's Avatar
$tonecold
I think you are talking about the adapter that come on the late models from the factory. I put one on my '09 and the one thing I noticed is it is really hard to keep the gasket lined up when installing it. Are you sure its where it needs to be?
Old Aug 7, 2011 | 10:08 AM
cllsr's Avatar
cllsr
Any news on this? I have developed the same issue. It started early this year and is a slow leak, but drives me nuts. It only leaks after prolong runs.
Chris
Old Sep 8, 2014 | 10:10 PM
hardheaded's Avatar
hardheaded
i tighten mine up to about 28 ft. lbs, of torque, it's just way to loose
Old Sep 9, 2014 | 12:55 PM
st john's Avatar
st john
I put the Harley Davidson brand oil cooler kit from Harley on my 2000 FLHT Std. six months later took bike in for service and dealer said it would be better to run without it and offered me a refund but would not explain why. I took the refund and now rethinking about what to do.
Old Sep 9, 2014 | 03:54 PM
hardheaded's Avatar
hardheaded
i know if you don't want it to leak you need to tighten it up alot more than the directions are telling you. i really torqued mine to about 28 ft. lbs. at first then put a ratchet on in and snugged it up some more. just don't go nuts on it, it's screwing into the right hand engine case.
Old Sep 9, 2014 | 09:56 PM
hardheaded's Avatar
hardheaded
just wanted to mention that the late 13 and 14 to current adapter is alot better than the earlier ones. they use an o-ring instead of a gasket.
Old Oct 2, 2014 | 08:26 AM
EasternSP's Avatar
EasternSP
I had that problem when I installed my oil cooler on my 06RG. Turns out that the adapter has to be tilted more forward so it seats down properly. If it's rotated back toward the engine it won't compress the oil seal properly.
SG103
Mar 29, 2017 05:25 PM
notrailers
Jul 16, 2011 11:20 AM
Everette
May 10, 2009 06:42 PM
r0de_runr
Nov 5, 2008 07:06 AM
FX4 Level II
Jul 16, 2008 12:44 PM
