Oil Archive (no new posts) An archive of oil related questions and comments.
leaking primary seal
Old Jul 22, 2012 | 05:44 PM
flhpken's Avatar
flhpken
Stage II
Question leaking primary seal
Has anyone experienced a leaking primary seal after switching from HD formula plus to syn 3. Road King FLHP, 07 with 33,000 on it. Had no leak at all before switch, at first thought it was drain plug, but is definatly coming from seal area, seems strange that it would go from no leaks to leaking with no other changes, first noticed within about 200 miles of fluid change
Old Jul 22, 2012 | 06:46 PM
trozenhorse's Avatar
trozenhorse
seems the synthetic oil has a way of flushing out leaky seals, lots of threads about the molecules etc. i changed my seal, it was easy, just mark the screws as you remove them, not sure they are all the same length, good luck!
Old Jul 22, 2012 | 08:07 PM
flhpken's Avatar
flhpken
Stage II
Default leaking seal
I was talking about the tranny shaft primary seal, sorry if that wasnt clear, have read in other posts where they say that the synthetic cleans out dirt left by real lube and it was already a bad seal, hard to believe
cc_Penguin
Oct 1, 2023 02:16 PM
Madfun
Nov 17, 2012 12:02 PM
msamarah86
Jun 25, 2011 01:43 PM
djw
Apr 20, 2009 01:52 PM
hoodlum
Aug 12, 2008 05:50 PM
