Oil Archive (no new posts) An archive of oil related questions and comments.
Oil Change Question
Old Apr 6, 2007 | 10:23 PM
chevelless502's Avatar
chevelless502
Default Oil Change Question
I have a 99 FXDWG and need to change the oil. If i look under the bike on the right side, (as if setting on the seat), there is a plug all the way to the right on what apperas to be the pan thats headed straight up, then to the left side of that there is a plug on the side of that pan thats horizontal, then there is an allen type bolt alittle farther back. Which plug do i remove to change the engine oil?
Sorry for the basic lame question but i am 60 miles from a HD dealer and dont want to end up draining the fluid out of the primary instead of the crankcase.
Thanks
Andy
Old Apr 7, 2007 | 11:26 AM
thrillseeker's Avatar
thrillseeker
Default RE: Oil Change Question
if you are sitting on the bike, its on the left to the rear, and its horizontal, to the oil flows out to the left rather than straight down.... on my 05 WG at least.
If you are 60 miles from a dealer and what to do the work yourself... do yourself a favor and pick up the service manual.
also, tq on the drain plug - 15 inch lbs will do it. (15 is right in the middle of th range the manual provides)
Also, do it while the oil is still warm from a ride so more of it comes out, and make sure to pull your dip stick to keep a vacuum from forming (just makes it take forever to drain on both these items, and with the warm part, it may not all come out... I think "stuff" may be suspended better as well)
Old Apr 7, 2007 | 12:32 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Look on ebay for a service manual or at Zanotti's HD or Chicago HD. You will save the price of the manual doing 1 oil service on your own.
TTS Performance
Milwaukee Eight (M8)
Jul 22, 2018 05:41 PM
harleyguy53
Aug 18, 2012 10:43 AM
94DYNADOG
Aug 4, 2012 12:08 PM
dubblist
Jul 17, 2006 12:07 PM
Hossman
Apr 21, 2006 09:58 AM
