hi....i am in the middle of services and thought i would do the oil change myself rather than the dealer.....i have a 1999 ultra classic.....wondering if there is any pics of the drain plug or good explanation of location....i have been told there are a few in the same area, i don't want to mess up ....thanks
Welcome to the forum! I don't want to be the first to tell you, but no one else has so here goes. Do yourself a big favor and invest in a Service manual for your bike. It will be one of the best investments you can make. Also buy yourself a good quality jack too. The initial investment may seem high, but once you look at what the dealer charges for services your investment will pay for its self very quickly.
You will have the oil drain plug and tranny drain plug on the underside of the bike. The best thing for a picture would be a service manual and a manual is a great investment and can really help you do several other things yourself. The only other thing might be youtube...sometimes people post such videos on youtube so might be worth checking out. If all of that fails then I believe your oil drain plug should be the one towards the front left side of the pan. The tranny drain plug will be facing straight down on the underside of the pan and maybe double check this before draining. If all else fails and you pull out the wrong one it will just cost you another quart of oil to put back into the tranny. The only other thing is if you are running syn. oil then you would only need to change your oil every 5000 miles but I'm not sure what you are putting in for oil so good luck.
