65 FLH Build Thread
Lower seat cushion. The 1x1x12 at the front combined with gradual increase in thickness of the seat pad raises the front of the seat up so its more comfortable to sit on.
Note direction of 1/2" plywood grain.
I'll measure the diameter and position of the vent holes.
Basically the side panel bottom isn't too specific. Its below the seat cushion and has to go over the clearance hump for the suspension cross bar.
The backing is cardboard like what you would find in the back of a picture frame. Thick hard paper I guess. The vinyl is stitched to the cardboard but its not attached to the armrest, just the vinyl continues on to the armrest underside and acts like a hinge. You need to be able to flip the side panel up to access the two nuts that holds the armrest to the top edge of the tub.
This measurement is directly under the rear stud. The angle of that panel is just a diagonal down to the forward corner. Again, no real rhyme or reason why they brought it down that far below the side of the seat cushion.
Another 1" strip of wood but they taper it at the ends.
I'll try to measure how deep the top 1" wood strip is.
