The Second Coming
Old Apr 17, 2025 | 07:26 PM
  #71
NM Pan-shovel's Avatar
NM Pan-shovel
Amazing work.. You used 5052 on the headlight bracket also? Did you precut the mounting tabs on the side of the rim? About the only thin metal work I've done a instrument buckets / bracket.
Thanks vey much. I crossed my fingers and got lucky…. My first piece was the dash as well.
Yes, 5052-H32 in .050” for both, McMaster 12” x 12” piece. Thicker might have torn around the sharp edge of the dumbell male die and perhaps broken the oak female along its grain. Lots of pressure from the press. Also, finish hammering with el cheapo HF body and fender kit hammer was a breeze with 5052 in .050”. Smooth face on the hammer nets clean radius & edge.
Right, as you can see, I precut the headlight ring blank to blueprint the aiming tabs’ location. They engage other piece in subsequent photos…
Note with precut blank featuring precisely located tabs, you need central hole to keep it centered (I used a socket bolted to die). I had guessed this was necessary and when I did the air cleaner lid, which of course couldn’t have a central hole, I had to reposition the sheet twice during press.
The aimer has a dynamic spring at the bottom for the adjuster clevis (red), and a static (conical) spring at top (green) to prevent rattling and hold adjustment. To my amazement, it works even with the Unit 650’s 360 degree crank..
Old Apr 18, 2025 | 03:33 AM
  #72
eighteight's Avatar
eighteight
You are one crafty guy
Old Apr 19, 2025 | 09:48 AM
  #73
NM Pan-shovel
Turns out the forged pistons are lighter than cast… I’ve decided to keep them, have my old cylinders bored to fit, oil them up and put them on the shelf. Right now, I’ve got a new top end that together with the ready-to-go .030 over backup should last until I’m old and gray.
The Sifton pin bushing tool is far cheaper than the other offerings, but works brilliantly. I had imagined using my adjustable reamer set but it was miserable going. So, ordered a dedicated reamer (Sifton), which will pay for itself first time out of the tool chest. Patient all ready for surgery, but another week delay…
BTW, I found this dash gasket, which is far superior to the plain U-channel sold by the usual suspects. Stays put on the dash rather than falling off, and looks like it’ll seal better, too.
Old Apr 19, 2025 | 10:50 AM
  #74
Rains2much's Avatar
Rains2much
Dude…. Respect. I was pretty pleased with myself welding up exhaust, making fenders and my own bars for my Shovel… but that headlight bezel/mount is just genius.
Old Apr 19, 2025 | 01:16 PM
  #75
TwiZted Biker's Avatar
TwiZted Biker
Loving all this, tech head **** at it's finest. Saw those wrist pin bushing reamers in somebody clearance section cheap and for the life of me can't remember where now. Made the tool long ago.
Old Apr 19, 2025 | 06:49 PM
  #76
NM Pan-shovel
Oh, man, thanks—but I think you’re too kind. I only wish I had a TIG machine to weld up a custom exhaust, something that looked like the Brough Superior SS pipes shown here…. and making fenders? Wow.
Anyway, working with aluminum is very forgiving. Eventually, I will bend up the sissy bar and ditch the rack for a p-pad, and that will mean welding up those bolt holes—and I suspect we’ll quickly run into the limits of my skillset.
Old Apr 19, 2025 | 07:00 PM
  #77
NM Pan-shovel
Well, I’m gratified you’re getting pleasure out of it. I find this stuff fun but it often feels like nobody around these parts appreciates it much.
Damn… I probably should’ve looked harder for a sale on the reamer, but it’s always worth buying a tool you’re gonna use more than once...
Lemme ask you something: do you like to drive the Sifton tool (stock pic) slowly by hand or with moderate speed using a motor? It looks like the valve guide spiral flute reamers I’ve used before, and I've just stuck them in a drill and got good results.
Old Apr 19, 2025 | 10:21 PM
  #78
TwiZted Biker
Originally Posted by NM Pan-shovel
What I’m seeing confirms what TwiZted said (no surprise there, obviously): a modern forged (low expansion) Harley piston will run quietly, with the rings lasting a long time, if set up with .0045” clearance.
Update: now I’m seeing .006” and even more recommended for TRW forged pistons. Hmmm… this may not be worth the headaches.
TwiZted: one poster who has used them said that a.016" gap for the top two rings is about right. Is that what you’d recommend? For some reason, I had .012” in my head.
Paul: I don’t mind letting her warm up a little while before heading out. (The Beemer airhead is so cold-blooded, I have to go inside for coffee before it’s ready to ride.)
Sorry I'm late back into this got busy with life a while. Off the top I use whatever the manufacturer recommends for ring gap, spec does vary a bit from brand to brand. I don't trust memory for anything when building, I'll reference EVERYTHING down to torque values I know by heart.
Old Apr 19, 2025 | 10:29 PM
  #79
TwiZted Biker
You have a lathe, slowest speed and run them through. Things are assembled I'll do them by hand so I can feel any tightness, maybe a hair misaligned kinda deal. Valve guides cast or bronze, power tool, big 1/2" IR air drill. Love my Neway set for seat cutting.
Old Apr 19, 2025 | 10:59 PM
  #80
NORTY FLATZ's Avatar
NORTY FLATZ
This, has GOT to be a first. Never seen an Akront shouldered rim with a disk rotor. Nope, not ever.
Well done!
