Searching for pushrods..
Old May 12, 2026 | 05:45 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by Ohio HD
Maybe send an email or call Gary Wallace at Andrews. He should know the radius. He's always been forthcoming with information when I needed it.
I talked to Gary a couple times. I've already got the PRs on order and they will be here Thursday.
Old May 15, 2026 | 08:57 PM
Max Headflow
Got the pushrods. Interesting one is longer than the other.. No biggie. I seem to remember one being adjusted longer than the others. Either way they all will fit. They don't use a compression nut but just a regular 5/16-24 so 2 1/4 turns instead of 3. They weight almost exactly the same as the stock ones, within a gram.
Old May 15, 2026 | 09:01 PM
Max Headflow
Here you can see the out or round of the pushrod end. They are supposed to be 15/64 radius. The new ones might be a couple thou smaller but they math the gauge well.
Old May 16, 2026 | 03:17 PM
wfolarry's Avatar
wfolarry
did you check the radius in the rocker arm?
Old May 16, 2026 | 08:37 PM
Max Headflow
I was going put it back together but you are right I should check em. I was over on hydro-glide.net and saw that the top caps are made of brass and not bronze. I'm pulling all the rocker blocks to see how they wear. The first appears OK.
Old May 16, 2026 | 08:43 PM
Max Headflow
As far as the radius goes they are the same. You can see where the older pushrod was hitting on the outside edge... I used a bronze colored sharpie, marked a line across the end, stuffed the VT pushrod into rocker running it with a drill. Obviously the parts need to run in but the contact looks good. I think I'll debur the oil hole.
Old May 18, 2026 | 02:24 PM
Max Headflow
I pulled the other rocker blocks and examined. They all looked better than the 1 above. I got to thinking (dangerous). The pushrod issue is the reason why the pushrod tubes were filling up. The fit on the rocker socket was so bad that a bunch of oil was leaking out and filling the tubes. Remember this?
https://www.hdforums.com/forum/panhe...l#post21858692
All the rocker sockets had a thin line like the one shown above.. With the contact ring way out on the outside edge and the pushrods not having a nice even radius on the end, I'd bet they were leaking a bunch. It's another reason why I've had the pushrod tubes weeping oil.
https://www.hdforums.com/forum/panhe...e-preload.html
Back to motor assembly. I guess it was a good thing I installed the pistons backwards.
FWIW, it's a good reason to reinstall pushrods back in their original spots. It's also worthwhile to check the pushrod ends to make sure the radius is still good.
Old May 25, 2026 | 09:51 PM
Max Headflow
The pushrods fit but were tight getting in.
Old May 25, 2026 | 09:58 PM
Max Headflow
After I ran it for a while the front exhaust pushrod tube leaked. I pulled it up and found that oil can fit in the lower part of the tube. Look where the oil drain is compared to the tube seat. Oil can sit in there. All the other tubes have better drains. I did a light cut in the lathe to make sure it was flat sanded with 120 grid while spinning to leave a circular rough surface. I've run it a couple times and it hasn't leaked. I used the blue. Only did the one.
RANGER73
Mar 29, 2019 08:56 AM
fergerburger
Shovelhead
Mar 2, 2018 12:25 PM
BB59
Jun 10, 2015 03:31 AM
TO34
Exhaust System Topics
Feb 14, 2012 06:31 PM
flyingdutchman
Dec 10, 2007 02:11 PM
