I have a 1960 FLH with Side car that I'm putting electric start on. Doing this requires me to convert it to 12v. I'm buying a generator from Cycle Electric. My question is: What else do I need to change? I'm thinking I need a 5ohm coil and new light bulbs. Is that it?
you'll need to change out the inner and outer to a 65 so it'll accept the solenoid and starter. Also the clutch basket will have to have the ring gear on it. Voltage regulator, horn. I think you'll need to change out the engine cc shaft. But I'm not 100 percent sure about that. Oil tank if you're not running one that will allow clearance for your starter motor.
I changed mine to 12v years ago. Glad I did not only the brighter lights also 6v bulbs and related items are getting $$$$. Good luck and keep us informed.
I converted a 41 knuckle to 12 volt about 25 years ago , but I think all I did was use a 12 volt generator from a panhead , eliminated the the voltage regulator as it's built into the newer generator , changed the coil and all bulbs , that about it as far as I can remember , it was a long time ago.
