Adjusting 50fl Solid Pushrods
Old May 14, 2010 | 10:37 PM
1bikenut's Avatar
1bikenut
1st Gear
Default Adjusting 50fl Solid Pushrods
Can anyone tell me how to adjust solid pushrods without springs on a 1950 Panhead. The tappets are adustable not the pushrods themselves. The manual only talks about hydraulic?????
Thanks!
Chris
Old May 15, 2010 | 07:14 AM
sqdealgeorge's Avatar
sqdealgeorge
Take off the clips pull the pushrod inner covers down to expose the pushrods Slowly rotate the engine over (spark plugs removed ) till the front exhaust pushrod is bottomed out Now tighten the tappet adjuster till the pushrod get somewhat tight to the point where you can roll it with your fingers Lock the adj nut then move to the next pushrod say front intake and do the same procedure
Old May 15, 2010 | 10:59 AM
1bikenut's Avatar
1bikenut
1st Gear
I appreciate the help!
swhitinger
Nov 5, 2013 04:27 PM
sugarplum247
Ironhead
20
Sep 20, 2012 07:52 AM
bubba 40
Shovelhead
Feb 8, 2010 11:46 AM
okiedokie
Shovelhead
Nov 9, 2008 03:29 PM
doc308
Panhead
Apr 16, 2008 07:29 PM
