help I.D. this frame
Old Jan 15, 2011 | 07:15 AM
tutty's Avatar
tutty
Stage III
Default help I.D. this frame
I just picked up this frame and was wondering if any one could help me identify it, I was told it had a pan motor in it back in the day but the seat tube was notch to get a shovel in, there is molding around the neck and on top of the seat post so there are no visable numbers, there are numbers on the axle plates XE-6 on the right and XE-7 on the left, the motor mount reads XE 621, any advice would be great thanks
Attached Thumbnails help I.D. this frame-tn-1.jpeg   help I.D. this frame-tn-2.jpeg   help I.D. this frame-tn-3.jpeg
Old Jan 15, 2011 | 11:51 AM
panz4ever's Avatar
panz4ever
Pics are just a thumbnail. Any chance you can post larger ones? And best advice I would give you is to have the frame bead blasted. The numbers you posted are general frame/casting numbers for pan era models. Depending on what was done and year, there are additional numbers near the top tank mounts and top motor mount
Old Jan 15, 2011 | 12:39 PM
mustasz's Avatar
mustasz
Seems to me like a Hydra Glide from early 50-ies,but it's hard to say looking at the small pics
Old Jan 15, 2011 | 01:48 PM
j1mmy's Avatar
j1mmy
looks like you have a part number in the picture,i cant read it but the last 2 numbers would be the year the casting was designed ie.0000-56..1956.every cast part of the frame will have a number but it will give you an idea..the only frame i have seen that needed notched was early knucklehead frames,i had a 37 that had a smashed in seat tube to fit a pan,shovel..i think there was a model/id number stamped on the rear axle block that gave the year
Old Jan 16, 2011 | 05:27 AM
Ultra 08's Avatar
Ultra 08
Hard to tell anything without closeup pics. Look on the right side of the top motor mount (near the top of it where it's welded to the backbone) and see if there is a production date code. "52 and later frames had this code stamped into the metal. Post closeup pics of critical areas and I'm sure you will get some answers. Show the top motor mount, steering head, bottom mount, etc.
Old Jan 18, 2011 | 09:39 AM
Speeding Big Twin's Avatar
Speeding Big Twin
The frame appears to be somewhere from 1937 to 1947. But it could be 1948 to 1951 because it’s hard to be sure from that full photo. The appearance of the top engine mount indicates a pre-1952 frame and that would not have a date code. Harley used a couple of types of top mount prior to 52 but I can't tell if that frame has the 48-51 style or the earlier type.
You mentioned there was moulding around the neck so I’ll assume there’s no sign of a steering head lock?
And I can’t tell what sort of front downtubes it has from the photo. If the front downtubes are straightleg that would help indicate 37-47 but if they are wishbone that would help indicate 48-51. Eric
Ss69camaro7
Jan 5, 2019 10:47 PM
derek_661989
Dec 7, 2013 05:48 PM
Vulcania Ironworks
Shovelhead
May 1, 2012 07:26 AM
rogue76
Shovelhead
11
Mar 3, 2011 07:10 PM
xcaret
Shovelhead
Apr 6, 2007 07:26 PM
