59 blowing condesors
Old Mar 31, 2012 | 12:03 PM
jkeplar's Avatar
jkeplar
Stage IV
Default 59 blowing condesors
It has been changes to 12volt, replaced coil, key switch, and rewired any ideas??
Old Mar 31, 2012 | 10:04 PM
panz4ever's Avatar
panz4ever
Couple of ideas of the top of my head.
Are you sure you have the coil wired correctly + to bat and - to timer?
Seen some made in Mexico that are POS and will not last but a few miles and crap out. Got a Delco Remy one around perhaps. Where you getting your condensers. Wondering if it the supplier.
Here is a link to another forum that talks about coil failure and will cause grief as well to your condenser
http://www.caimag.com/forum/showthre...uot-coils-Fail
Old Mar 31, 2012 | 10:24 PM
jkeplar's Avatar
jkeplar
Stage IV
I know the coil is good it works on my brothers 38 knuckle and my dads shovel I have tried all different types of condensors form harley shops and local parts stores.
Old Mar 31, 2012 | 10:58 PM
j1mmy's Avatar
j1mmy
can you put a standard ignition in the dist?? if so,run a dyna-s you will never have to think about it again..
Old Apr 1, 2012 | 10:39 PM
panz4ever's Avatar
panz4ever
Couple of more thoughts...
Is this a recent conversion? Is the generator charging? Did you "flash" the generator before starting?
Is the engine grounded to the frame? No powdercoat BS in the way, etc....
Old Apr 2, 2012 | 03:00 AM
mkguitar's Avatar
mkguitar
+1 on checking polarity.
the job of the condensor it to keep the points from arcing and pitting.
You could replace all that with this:
http://www.ebeyond2000.net/quickstart.html
which I use on my '53.
It is flawless and worth every penny.
Mike
Old Apr 2, 2012 | 12:00 PM
jkeplar's Avatar
jkeplar
Stage IV
I built the bike 8 years and Its started happening at the end of last year,
Old Apr 2, 2012 | 08:36 PM
panz4ever's Avatar
panz4ever
...the job of the condensor it to keep the points from arcing and pitting...
This got me to thinking but I did not have time today to get out and look through my timers so I will just throw this out and check tomorrow...
Aren't condenser posts isolated? as in some type of Bakelite material, washer or paper gasket that isolates it? so if the points are arcing this would cause condenser to blow? maybe?
I will take a look tomorrow and post a pick of the top (showing post) as well as the underside of the circuit breaker base (where the wire connects). Everything keeps coming back to the timer from what you have posted.
sB43
EVO
23
Feb 6, 2018 04:45 PM
Steen
Feb 5, 2016 05:44 PM
71shovelpolicespecial
Shovelhead
Apr 14, 2013 02:17 PM
hdbeggs
Feb 14, 2011 02:22 PM
Omen
Sep 21, 2008 05:29 PM
