Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
Paint dry time?
Old Mar 3, 2012 | 09:38 AM
PHA-Q's Avatar
PHA-Q
Default Paint dry time?
Just had all my tins painted!!
How long do i wait till i can start putting it back together?
I've heard wait till you cant Smell the Paint anymore!!! And just wait a day or two!!!!
Waiting for the rest of the powder coat to get finished then the bike will be at a whole nother level... I may have taken the BLACK out to the extreme !!!!
Old Mar 3, 2012 | 09:50 AM
1CdnHD's Avatar
1CdnHD
Ask your painter.
Was it baked or air dried? It may be still gassing off after 24hrs but as long as the painter used the products as per tech sheet, you should be able to put it together after 24hrs.
Old Mar 3, 2012 | 09:54 AM
PHA-Q's Avatar
PHA-Q
Painter said (put it on) just be careful!!!
I left it in the car and did a few things, came back and the car had a heavy paint smell... I'll give it a couple days... I guess!!!
Old Mar 3, 2012 | 09:58 AM
JRK5892's Avatar
JRK5892
get it out of your car man, the temp changes in there are nuts... get it in a constant temp so that it can properly cure
Old Mar 3, 2012 | 10:19 AM
PHA-Q's Avatar
PHA-Q
It was only in the car for about an hour & a half.. Its in the house now... Supposed to be 75-80 degrees here in Ca today. I'll get in in the garage to ramp up the temps... I may start putting it together 2moro..
Sun is supposed to be 81 degrees.....
Old Mar 3, 2012 | 10:26 AM
JRK5892's Avatar
JRK5892
nice!
Old Mar 3, 2012 | 11:41 AM
Colormania's Avatar
Colormania
Your painter did not cure the paint enough, otherwise it would not smell. I would not bolt it on yet, all the pressure points will push the paint away causing it to lift! Do not lean the paint against the car seat for longer than a few minutes as it may leave an imprint on the paint surface!
I would put the parts outside under the sun to cure over the weekend.
To cure paint; you need heat (above 85F) and air movement.
At Colormania we bake all our paint jobs for 24 - 48 hours at very high temperatures (140F+). This form of Force Curing simulates 6 months of curing time under normal conditions. A costly process, but assures long-lasting shine & quality.
Old Mar 3, 2012 | 11:52 AM
PHA-Q's Avatar
PHA-Q
Thanks for the heads up. I'll sit on it a few more days, I have to wait for my powder coat to get done anyway....
Old Mar 3, 2012 | 12:31 PM
07bobber's Avatar
07bobber
yeah id wait a few days, when i got my tank painted i waited 24hrs and put it together. now when i take the dash off you can see the outline of it in the paint.
Old Mar 4, 2012 | 08:51 AM
PHA-Q's Avatar
PHA-Q
Then im deff waiting. I dont want any Issues.,,
