Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch engages when starting
Old Sep 18, 2015 | 12:20 PM
mandd71974's Avatar
mandd71974
Default Clutch engages when starting
Recently purchased a 2010 Ultra Classic and when I hit the start button with the bike in gear and the clutch lever pulled all the way in, attempts to lunge forward slightly. Is this in any way normal or do I need to adjust the cable, etc...?
Old Sep 18, 2015 | 01:32 PM
Next In Line's Avatar
Next In Line
Sounds like the clutch cable needs to be adjusted.
Old Sep 18, 2015 | 03:23 PM
jmn1960's Avatar
jmn1960
my 2005 does the same thing but it still starts then all is normal,, so I just start it in neutral,, but I do sometime still start in gear ,, so I would say it is normal
Old Sep 18, 2015 | 04:13 PM
clovisrider's Avatar
clovisrider
Maybe try pulling the clutch lever and release once before starting. I think I read once that's just the clutch plates sticking at start up. It's worth a try.
Old Sep 18, 2015 | 07:18 PM
Rubline's Avatar
Rubline
My 14 Fat Bob does the same thing, adjusting the clutch or cable does nothing, it's normal.
Old Sep 18, 2015 | 08:21 PM
HDmikie's Avatar
HDmikie
Start in neutral...I think the manual even states same. It's not so bad when starting in gear when the motor is warm.
Old Sep 25, 2015 | 12:39 PM
soft 02's Avatar
soft 02
Normal.
Old Sep 25, 2015 | 02:47 PM
SIDECAR BOB's Avatar
SIDECAR BOB
as someone else said , usually caused by the clutch plates draining off after sitting a while , not unusual to happen, clutch adjustment may take care of it if you set it to be a bit "loose"
ejs262
Jul 15, 2015 06:10 PM
EZRider76
Apr 29, 2015 07:55 PM
All Aces
Mar 10, 2013 11:36 PM
Frog33
Mar 4, 2009 09:57 AM
hemel
Jun 22, 2008 08:43 PM
