Which Compensator
What compensator is being recommended? what chain adjuster?
Baker, Hayden, Screamin Eagle? Mine is original. Stage 1, rhinehardt true duals, Andrews 48h cams. Rattles like hell since new
https://www.hdforums.com/forum/touri...l#post14919797
Get the SE compensator package for your bike that includes the new rotor assembly if you haven't already changed it.
As for the tensioner I a switched from the Hayden M6 to the Baker because when your hot rodding a lot, like me, and motor is built up I think the Hayden gives to much when loaded. The baker you set at the right tension and you know it ain't going to low under load.
