Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch slipping
Old May 15, 2016 | 08:15 PM
Checkvalve's Avatar
Checkvalve
6th Gear
Default Clutch slipping
I was coming back from Denver this week. The clutch was slipping in 5th gear on my sporty. It would redline if I pulled more than a quarter throttle. I installed a barnett extra plate kit about 14000K miles ago. I use type f atf Super tech walmart cheap stuff. I replaced the fluid the and adjusted the clutch under the derby cover and cable. I the clutch does not slip anymore. I just thought that was odd it would slip that bad and that fixed it. I see a lot of crv's and vehicles with lsd's while corning and I change the fluid and all is well. So I guess it's not that amazing. I know some diffs have clutch packs like bikes. It's been about 10,000 miles since I changed the fluid. Is this normal or should I be looking to get a new clutch soon.
Old May 15, 2016 | 08:17 PM
QC's Avatar
QC
Did the fluid that you drained smell burnt?
Old May 15, 2016 | 08:27 PM
Checkvalve's Avatar
Checkvalve
6th Gear
It did smell burned. It smelled like the new type f did just stronger.
Old May 15, 2016 | 08:33 PM
QC's Avatar
QC
having a burned smell isn't good. Keep an eye on the adjustment. Pretty difficult to ruin a wet clutch in normal use, but it can be done. Riding it with a slipping clutch for a thousand miles could do it.
wdb1264
Jan 1, 2015 10:23 AM
Willetts1
Feb 16, 2014 09:41 PM
bigredwing
Sep 1, 2011 11:00 AM
94softtail
Jan 4, 2010 04:35 AM
flyboyjacko
Sep 15, 2007 04:59 PM
