Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Primary grinding sound
Old Jul 1, 2019 | 08:49 PM
Rick Ortiz's Avatar
Rick Ortiz
6th Gear
Default Primary grinding sound
I have a iron 883 2016 and couple month ago start a grinding sound on the primary when decelerating, i consult with a mechanic and finally find a clutch hub bearing its moving and its not supposed too, so i replaced it and the grinding sound goes off in some of the gears but left it in 4th gear when decelarating. Couple days ago i take the primary off to check everithing again and i see that the clutch hub have a movement just like the other bad bearing. So i not sure how two bearing can be damaged. I am replacing again. The sportster have only 4000 miles. Maybe the mechanic replacing the first bearing damaged it, maybe its why still grinding? When pull the clutch stop.
Rick Ortiz
Jul 1, 2019 12:43 PM
lopoko9724
Oct 31, 2017 06:17 AM
highwayking
Mar 23, 2014 08:13 AM
trackadaptor
Jun 22, 2012 06:22 AM
jasonmrenda
Nov 23, 2010 12:21 PM
