Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch adjustment
Old Sep 17, 2007 | 09:28 PM
BigJohn's Avatar
BigJohn
Default Clutch adjustment
Just bought a new 07 Night Train, and after replacing the levers, I adjusted the cable 'as per specs', and now the clutch engages really quick, right off the grip. Is this normal? My 06 RK Custom has the same amount of play, but engages much later. Any advice will be appreciated, as long as its not abusive. Or at least not too abusive. Thanks.
Old Sep 17, 2007 | 09:55 PM
darkside's Avatar
darkside
Default RE: Clutch adjustment
I found on my bike that spec was a really good starting point but not exactly how I liked it.You can run a little more slack in the cable if you want(not alot but some) or tighten it up a little.If you get it to tight it will let the clutch slip(not good).What I,m getting at is, if you don't like it .adjust it so you do.If your bikes brand new that cables gonna be stretching and the clutch wearing in and changing things until everything is settled in as well.
Old Sep 18, 2007 | 01:09 AM
BigJohn's Avatar
BigJohn
Thanks, I will tinker around a little and see what happens.
Old Sep 18, 2007 | 05:32 AM
mopardave's Avatar
mopardave
You will want to run a little bit more slack than they tell you to. It's most likely a little trade-off for the easier pull rate.
Hey Man
EVO
11
Jul 8, 2017 03:28 PM
Glyder54
Aug 31, 2016 08:40 PM
PKS98S
Sep 1, 2013 04:12 PM
wu8always
Jun 4, 2012 09:27 PM
Coloradohunter
Mar 28, 2012 04:07 PM
