Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Screamin Eagle Big Twin Compensator
Old Oct 30, 2008 | 06:27 PM
  #51
rbabos's Avatar
rbabos
Absolutely!
Ron
Old Nov 1, 2008 | 02:15 PM
  #52
rbabos's Avatar
rbabos
Just got a chance to run with the new big twin comp. Now keep in mind my modified unit was working fairly good as far as removing clatter, and starter knock.
The obvious difference on the new one is a quiet startup, even less noise than mine. There is no driveline noise, as far as trans clatter and comp seemed quiet even with some light lugging. The feel of the bike is about the same cruising and with higher power settings it was smoother since mine would go solid. The off the stoplight normal launch is smoother as well, as mine used to shudder sometimes if there wasn't enough throttle input.
Had I switched from the stock unmodified unit and put this new model on I would be most impressed with the difference. More miles and time will tell more, but for now I give it a thumbs up. By the way, it is not necessary to remove the clutch basket when changing a comp. Remove the tensioner and there is enough slack to get all the parts in. First the extension shaft, then the discs and the sprocket with the chain on it last.
Ron
Old Nov 2, 2008 | 01:20 AM
  #53
redrazor's Avatar
redrazor
Question Still no part number(??)
I've been following this thread for a while now. I've done everything to try to eliminate the noise problem in my lower front primary case area; re-torqued comp bolt; installed (expensive) IDS sprocket, etc. on my '07 FLHX. I've done most of my own work for years; and am ready to tackle the SE Comp install; but am lacking one important bit of info on this project ......
the Part Number!???
Please help me out with this info; ...... and thanks so much for all the good input on this PITA issue.
thanks again,
redrazor
Old Nov 2, 2008 | 06:54 AM
  #54
Dalton's Avatar
Dalton
Good input Ron.
Mine goes "solid" also as I have not modified the spring pack on the stock unit. I just may give it a try. Sure wish they made it in a 32 tooth.
Old Nov 2, 2008 | 07:06 AM
  #55
twilliams's Avatar
twilliams
Originally Posted by redrazor
the part number!???
please help me out with this info; ...... And thanks so much for all the good input on this pita issue.
Thanks again,
redrazor
40274-08
Old Nov 2, 2008 | 07:07 AM
  #56
r0de_runr's Avatar
r0de_runr
the Part Number!???
thanks again,
redrazor
Page 513 of the 2009 catalog. Item I, part number 40274-08 $249.95 / $209.94 at Zanotti's.
Old Nov 2, 2008 | 08:54 AM
  #57
rbabos's Avatar
rbabos
Originally Posted by Dalton
Good input Ron.
Dalton: I think this would be the perfect comp for your 120. Not sure what it would take to bottom this one out, but compared to the stock one you will have to work at it. First third of travel is soft. This gives a gentle startup and smooth cruise. Add power and it's in the next set of springs. If that's not enough, there are two more big mothers left that defy you to try and bottom them out. I have no idea how it will behave with the ids, but it's the cat's a$$ for the softail.
Ron
Old Nov 2, 2008 | 12:43 PM
  #58
twilliams's Avatar
twilliams
Ron,
Your review give's me great hope that this "upgrade" will remedy my problems.....oh and yes I did go ahead and order the chrome primary...I just could not resist
Old Nov 2, 2008 | 01:23 PM
  #59
redrazor's Avatar
redrazor
Thumbs up Many Thanks, indeed!!
Thanks to all of you for the much needed part number. I'm still using my '08 Parts and Accessories catalog; ..... guess I better go down to my dealer and get the '09 "bible".
This problem started bugging me about a month or two after we bought the bike. (about 1 1/2 years now!). Since I found out that it wasn't a "lazy lifter" or piston slap, or other major component malfunction; I've tried to ignore it.
Wrong!!
Every time I wind it up between 2,800 and 3,200 rpm while accelerating it gives out that damn rattle noise; and I've started hearing it in my sleep for crap sake!
I'm 95% sure that this SE Com Sprocket will finally let me get some piece of mind ...... and maybe a good night's sleep too!!??
Thanks again for the insight and the info.
good luck,
redrazor
Old Nov 3, 2008 | 11:47 AM
  #60
GAstreetglide's Avatar
GAstreetglide
I've put about 200 miles on the 103 upgrade and installation of the new SE compensator and I fully agree with the comments provided by rbabos. Since the top end of the motor is all new I haven’t really been banging gears or running it wide open. However, the motor feels a lot stronger, sounds much better, and the SE compensator is a major improvement to the driveline.
