Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Transmission Leakage
Old Jan 3, 2009 | 08:08 AM
03eglide's Avatar
03eglide
1st Gear
Default Transmission Leakage
Hello all - new member needing some advice. 03 E Glide - leaking what appears to be fluid on floor of garage. Have read many posts ref this topic and most sound as if the leak is coming from left side of bike i.e. inner primary seal, shaft seals, etc. In looking at mine closely, it actually appears that my leak is originating on the right side of the transmission, trailing down right side, then across oil pan and finally dripping off the oil pan plug making it look like an oil leak (until you smell the drop). I'm thinking I may just have some loose bolts but am going to clean it up today, heat it up, and take a real good look at it again. Has anyone had a similar experience?
thanks for you help - this seems like a great place to get it!
Old Jan 3, 2009 | 03:27 PM
stroker1948's Avatar
stroker1948
yes, your problem is not an uncommon one. In my shop I have seen the transmission trap door bolts loosen and leak down the right side and under the pan, just like you are talking about. You will need to drop the exhaust pipe out of the way and pull the oil filler spout
(replace with a new gasket) in order to get to the bolts. Loctite them and torque to spec and this will solve your problem.
Stroker
Old Jan 3, 2009 | 06:52 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Check the oring on the clutch cable where it comes into the trans.
Old Jan 4, 2009 | 02:51 PM
03eglide's Avatar
03eglide
1st Gear
Thanks for the replies....I cleaned the whole thing up today and rolled it in and put it on the lift. I'll check both things and hopefully clear up the problem. Thanks again for the advice, I really appreciate the help.
Bob
Old Jan 5, 2009 | 05:00 PM
03eglide's Avatar
03eglide
1st Gear
Default Thanks Stroker!
My thanks to Stroker for telling me about the trap door problem. I cleaned the bike up, got underneath after it was hot, and found that one of the bolts to the trap door had actually worked itself about half way out....this is definitely the problem.....have it up on the lift and will tighten up all trap door bolts with locktite per his advice......thanks again, Stroker!
mang0
Jul 1, 2016 08:55 PM
hallfleming
May 22, 2015 10:33 PM
xdanman
Jun 9, 2014 05:44 PM
havoc1354
Exhaust System Topics
Dec 3, 2012 08:40 AM
bykrdan
Ironhead
Dec 21, 2007 03:25 PM
