Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Broke Jackshaft Bolt**Help
Old Mar 15, 2009 | 04:18 PM
bazam9s's Avatar
bazam9s
Default Broke Jackshaft Bolt**Help
Well I did it. Snapped the jackshaft bolt right off at the tip. I was watching changing my inner primary and I checked out fix my hog and it said 108 inch pounds. Didn't double checkthe manual which said 60 to 80 inch. Well snap it went. Realized after the video was changing an inner on a Dyna. I have an 05 EGS. I was told by them the same procedure apply's...I guess not.
So what do I do now? Remove starter? Can the broken tip be taken out?? Any suggestions would certainly help...thx
Old Mar 15, 2009 | 06:02 PM
dawg's Avatar
dawg
Can you get in with a drill and e-z out? I broke my compensator bolt off and had to drill it out and insert an e-z out and back it out. Ooops, re-read your post and see what broke off. You're going to want to remove the starter.
Old Mar 15, 2009 | 06:09 PM
rbabos's Avatar
rbabos
Man, that had to suck. HTF did you manage to break it off?
Ron
Old Mar 15, 2009 | 06:46 PM
dawg's Avatar
dawg
Ron
I stupidly thought I could use a hollow handle from a floor jack as leverage on my ratchet and "snug it down" because my foot pound torque didn't go that high! This is when I put in the EVO 30 tooth. After I fubared it, I borrowed a bud's big azz snap on torque wrench and got the job done properly. Boy that was scary until the e-z out worked.
Old Mar 15, 2009 | 07:49 PM
rbabos's Avatar
rbabos
Yup, I'd break into a cold sweat for sure if that happened.
Ron
Old Mar 15, 2009 | 08:10 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Yeah...that would be a Polish torque wrench.... I quit using those a long time and long trail of snapped off stripped $hit ago...
FreedomRider
EVO
Oct 2, 2017 06:54 AM
Road Star
Nov 28, 2016 11:40 PM
JustDave71
May 26, 2010 12:54 PM
bazam9s
Exhaust System Topics
Mar 15, 2009 07:58 PM
hatchetman
Nov 2, 2008 10:54 PM
