Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Alignment question
Old May 7, 2010 | 02:16 PM
Jim Kraft's Avatar
Jim Kraft
Default Alignment question
On my 99 Softail Custom, if I align the rear wheel by measuring from the center of the swingarm bolt, to the center of the axle, my belt runs up against the inner side of the pulley. If I adjust it so that the belt runs in the center, then I am off at most a 1/16" on the measurement from the swingarm bolt to the axle. My question is, which way should I use? Alignment by measuring, or alignment by where the belt runs in the center of the pulley? Thanks for any and all replys.
Old May 7, 2010 | 02:38 PM
TW's Avatar
TW
Align it so the belt is straight.
I've had a bunch of Softails and the rear wheel has never been exactly centered under the fender.
Old May 7, 2010 | 04:55 PM
Jim Kraft's Avatar
Jim Kraft
Thanks TW; That is what I did, as it just seemed logical to me. It isn't off more than a 1/32" to a 1/16". Drives just fine, and I like the belt in the center.
Village Idiot™
Mar 12, 2013 08:35 AM
busterman2
EVO
Aug 17, 2011 02:17 PM
t stone
Aug 10, 2011 03:38 PM
GPHDXLC
Feb 6, 2008 12:10 PM
