Question about wheel removal/replacement
Old Mar 11, 2013 | 10:15 AM
Village Idiot™'s Avatar
Village Idiot™
Default Question about wheel removal/replacement
OK, I need to take my rear wheel off to finish up some shaving of the inner fender liners. My questions is how should I go about doing it to make sure that the belt tensioners end up in the same place as when I remove it.
I removed it previously and had someone do that for me but this time I'm doing all the work on my own and I want to make sure everything gets done correctly.
Old Mar 11, 2013 | 11:00 AM
QC's Avatar
QC
Try to measure the distance from the center of the swingarm to center of the axle on each side and record it. When you put the wheel back in, make the numbers match. You can back this up by measuring the distance the adjustment bolt is sticking out from the frame on both sides as well.
Old Mar 11, 2013 | 02:42 PM
fergml's Avatar
fergml
My service manual stated to mark the adjustment bolts and count the number of turns on each side.
I just removed my wheel and was able to slide it out with 5 full turns of each bolt.
Old Mar 11, 2013 | 04:24 PM
jreichart's Avatar
jreichart
Just back them off so the axle will slide out. When reassembling, you'll need to reset the belt tension anyway, so just use that as your guide. When the belt is properly tensioned, that is where the adjuster should be. Easiest way to accomplish this is to back them all the way off. Reinstall the axle and snug up the axle nut so it doesn't move freely, but can be moved with a little pressure. Walk the axle back using the adjuster nuts, alternating side to side so the adjusters are approx. equal, until the belt reaches proper tension. I think it's 3/8"-5/8" deflection at 10 lbs of pressure, check your manual for exact numbers. With the bike on a lift, sit behind it and spin the rear wheel forward for a bit, then backward while watching the belt in the pulley. It should not walk around the pulley when changing from forward to backward rotation. If it does, adjust the right side adjuster in small increments until the belt runs a stationary track in both directions. Double check the alignment by measuring the adjusters (should be approx equal both sides), measure from the center of the swingarm pivot to the center of the axle (should be within 1/16" side to side), and then double check that the belt tension is within spec. If the belt ends up too tight after the adjustments, loosen that adjuster slightly and repeat the process. Then torque everything and take it for a shake down ride. Note the location of the belt in the pulley, it should be in the exact same spot at the end of the ride. It can be a lengthy process to get perfect, but your tires and your wallet will thank you for your patience.
Old Mar 11, 2013 | 06:34 PM
Alter's Avatar
Alter
I just marked the bolt at 12 oclock with a fine sharpie, counted the half turns I loosened just far enough back to remove the belt without taking the bolt out and reversed the process to put the belt back on.
Old Mar 12, 2013 | 07:55 AM
Village Idiot™
Yeah, how many times have I said it already? I need a manual.
Old Mar 12, 2013 | 08:00 AM
QC's Avatar
QC
YUP!
Old Mar 12, 2013 | 08:03 AM
Dan33klein's Avatar
Dan33klein
Village, I will try to find the link. But when I started my 98" build I bought the factory service manual online for 8$ pdf file.
When im out working i just have my laptop with me and can navigate faster than a book for what info I need.
Of course im really young so it seems easier. Im sure some people prefer the hard copy.
You can also print sections you will be using.
It also includes all the electrical manuals and such.
Only 8$ and you get it via email in about 5 minutes
http://www.repairmanualsoncd.com/har...ce-manuals.php
This is where i got mine 8$ Mine is a 2001, For all softail models including deuce and springer.
Check it out if your interested
Old Mar 12, 2013 | 08:20 AM
Village Idiot™
Hey now, I'm not that old. I won't be 31 until Sunday. Why do you think I'm always harrassing the old guys on here?
Old Mar 12, 2013 | 08:35 AM
Dan33klein's Avatar
Dan33klein
I haven't been around long enough to notice...
But you'll be 11 years older than me! I just turned 20
johnod
EVO
Jul 26, 2014 08:10 AM
mang0
Apr 6, 2011 05:11 PM
Beauregard
Jan 28, 2010 10:28 PM
RocketRocker
Nov 18, 2009 09:31 PM
GPHDXLC
Feb 6, 2008 12:10 PM
