Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
compensater spring tension. 03 fatboy
Old Dec 27, 2011 | 12:06 PM
djl's Avatar
djl
Originally Posted by grf000
I still think you and I may be referring to a different thing. The decrease space I was referring too was from what I thought heybalor was revering to decrease by either adding another cup spring to his original pack or add a spacer inside to put some more pre-load on it. Adding a space inside the spring pack would only alter initial pre-load and not increase actual compression value (what ever that is) like another spring would. If you note my old album in my grf000 you will see I was careful when I set mine up a few years ago to make sure the area were you have the red circle to show and attempt to translate the fact that that area is very close. Think when mine torques at 165 the inner gap is only a 1/16" or so. I can see why you would add a shim that you show. I get now what you are saying.
Did you do the picture on CAD. Like to get a bigger copy of it for my forum folder if you don't mind. Pictures worth a 1000 words. Thanks.
I have lost the original file; don't remember if it was ACAD or not; you will just have to save the .jpg file and work with that.
Old Jan 7, 2012 | 10:10 AM
heybaylor's Avatar
heybaylor
update,,
problem solved.
300+ miles in the past couple of weeks many ,many starts hot and cold .
no noise, no banging...
I am going to lay the blame on weak compensator springs in the original springpac..
and shaving 35 thou off the clamping nut was insurance
heybaylor
Nov 14, 2017 08:26 PM
newdyna
Apr 12, 2016 08:38 AM
MrSunset
11
Sep 26, 2012 08:57 PM
mplecha
Sep 26, 2008 03:49 AM
grounded7
Shovelhead
Jun 6, 2008 08:29 AM
