Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Speedo error correction!!
Old Mar 18, 2012 | 04:16 PM
Fastrider124's Avatar
Fastrider124
Default Speedo error correction!!
I have an 01 Dyna, 124 T S &S motor, chain final drive 24/48 sprocket, std 25/36 chain primary. I used a Thunderheart speed sensor to recalibrate the speedo 11% to correct the speed error with the taller gearing. Final gearing is 2.88/1
Last fall, the speedo suddenly dropped about 20klms/hr, instead of reading 80 @ 2100 rpm, it started to read 60klms/hr@2100rpm. I have made several attempts to use the setting on the Thunderheart adj sensor to correct this, but there is no changes at the speed. The sensor seems to take the new settings, all the approriate flashes etc, but no changes happen at the speedo.
Is this still likely to be the speed sensor, or have I got a speedo going down. All other functions on speedo are normal. Thanks in advance for any help. Fastrider 124
bigsteve799
Sep 21, 2023 12:05 PM
TSheff
Apr 22, 2014 06:56 PM
Tattoo_u
Sep 18, 2013 04:03 PM
armymedic54
Mar 19, 2012 03:15 PM
emeraldbiker
Aug 14, 2006 10:32 AM
